Rotaryracer
Rotaryracer Reader
5/11/21 1:04 p.m.
In reply to SVreX (Forum Supporter) :
Thank you - this makes a ton of sense.  And yes, while there's a very slight chance that I might be pulling a late night wrenching session and charging the cars at the same time, the reality is that the rest of the house will probably be powered down.  99.9% of the time, the barn and house would be quiet during late night hours.  I'm not 18 any more and I fall asleep early.  :)
Is there a recommendation for how to best calculate actual amperage load?  Did some internet searching and most of it seems designed around "how big of a main panel do you need" versus "how little am I actually drawing from my current panel"?  I'm assuming it's just a product of finding all the junk that could be on simultaneously when we would/would not be charging, determine consumption from each device, and add it all up?
Tyler H (Forum Supporter)
Tyler H (Forum Supporter) UberDork
5/11/21 1:25 p.m.
How I do it -- calculate all the major appliances and HVAC for max load on home runs, add in lighting, then reasonable guess on 15a per string of outlets.  Once I have a plan that makes sense to me, I hire an electrician.  Got high marks for my best-guess design, but I didn't know that all refrigerators had to be on dedicated circuits, etc.  I just don't want to fly blind when hiring contractors.
For just adding a circuit or two myself, I Google it and use common sense.
stuart in mn
stuart in mn MegaDork
5/11/21 3:04 p.m.
If you do a search on 'load sheet calculation', a number of links should show up with a standard load calculation form for your total electrical load.  You go down the sheet and fill in the blanks, it's fairly straightforward.
WTCreIzso8SXoHwdS6tqL90e3topSYetLwXM2nuLpTYGlEdP1Ng2lPUAsccfPpWD
