Fitzauto
Fitzauto HalfDork
8/19/15 9:55 a.m.
Is there a kit for installing a single din radio into an na miata or does something need to be fabricated?
SlickDizzy
SlickDizzy PowerDork
8/19/15 9:58 a.m.
Googling "Miata single DIN radio" brought up this install kit at Crutchfield. Google shows a bunch of other options as well. http://www.crutchfield.com/p_120997505/Metra-99-7505-Dash-Kit.html
mistanfo
mistanfo UltraDork
8/19/15 10:26 a.m.
Depends on the year, the dash changed at some point, but I cannot recall when, maybe between 1995-1996?
LuxInterior
LuxInterior Reader
8/19/15 10:36 a.m.
Dash changed in '94
evildky
evildky SuperDork
8/19/15 1:30 p.m.
I put a mazda 3 cd player along with a cubby form some junkyard mazda in my last na, plug and play.
CyberEric
CyberEric New Reader
8/19/15 4:08 p.m.
It was pretty easy in my 97, you just need to find a little cubby to install in the empty space. Crutchfield helps you know if the deck will work on their website.
8/19/15 4:15 p.m.
There are factory cubbies available for the 1.8 cars. The 1.6 cars are awkward, the hole is almost but not quite 2.5 DIN so some surgery is required - or you buy an expensive JDM center console that has a proper 2.5 DIN opening.
bluebarchetta
bluebarchetta New Reader
8/20/15 8:09 a.m.
The Metra kit for the '90-'93 is a bag of crap. I highly recommend the DDMWorks kit: http://www.ddmworks.com/Miata-Radio-Surrounds-by-DDMWorks_p_187.html
It's not cheap, but it results in a rock-solid installation that looks great. You can even get it with holes for gauges if desired.
car39
car39 HalfDork
8/20/15 8:52 a.m.
I used the metra kit in my 90. Not great, but it's worked for the last 2 years with some small mods to make it stronger.
MCarp22
MCarp22 Dork
8/20/15 9:23 a.m.
I had the Metra kit also, it wasn't too horrible. This pioneer wouldn't fit in the DDM kit for some reason:
Sky_Render
Sky_Render SuperDork
8/20/15 10:16 a.m.
You should use the second DIN slot to put in some gauges. I know I've seen ready-made gauge panels.
C3FlyWe6XX3YpaE5bHmS6MJVzhcuyBG1oJr3I6tVTnghctVV2xxkhHpD9ZWlYGRJ
