Cuda
Cuda New Reader
11/4/12 8:05 p.m.
So there is this E36 hatchback near me that has been sitting with one jack stand under the front driver side. It has been sitting for 4 months or longer. Will the body/frame have flexed to a point of irreparable damage? I want to go throw a low ball offer on it, but I don't want to buy a car that will always pull right, or have some suspension nonsense going on.
Giant Purple Snorklewacker
11/4/12 8:07 p.m.
You could put it under the other side to even things out :)
If the doors open/close w/o problems and the windows fit tight I wouldn't worry too much about it.
Per Schroeder
Per Schroeder Technical Editor/Advertising Director
11/5/12 8:10 a.m.
I would have to assume that steel body structures won't undergo plastic deformation at that low level of force. And by plastic, I mean the point where steel and other materials start to bend/yield without springing back into shape.
Now, if an elephant sat on it whilst it was sitting on that one jackstand, then we'd have a problem.
N Sperlo
N Sperlo PowerDork
11/5/12 8:32 a.m.
"... and have any elephants seated themselves upon your vehicle lately?"
Duke PowerDork
11/5/12 8:35 a.m.
If it's a hatchback, you're probably fine. I left my old Le Mans ragtop up on one stand for a couple days and it cracked the windshield, but you could see the cowl shake on concrete expansion joints, so it is no surprise.
slopecarver
slopecarver New Reader
11/5/12 10:21 a.m.
The term you are looking for here is "creep" I don't have an answer for you but it will help your search go quicker.
mad_machine
mad_machine MegaDork
11/5/12 12:09 p.m.
the Ti has a pretty stout body structure compated to the coupe' and cabriolet.. it might even be stronger than the sedan,
Unlike the coupe', it has framed doors that help with the structure. It also has a longer roof than the coupe' or the sedan.. and especially compared to the cabriolet.
Kenny_McCormic
Kenny_McCormic HalfDork
11/5/12 12:12 p.m.
You jack the car in the same fashion if only working on one corner. Its designed to handle that kind of stress.
Gearheadotaku
Gearheadotaku SuperDork
11/5/12 12:14 p.m.
Is that corner way up or is the car fairly level? Still wouldn't worry much about it.
mad_machine
11/5/12 5:42 p.m.
Kenny_McCormic wrote: You jack the car in the same fashion if only working on one corner. Its designed to handle that kind of stress.
True.. this is a not early 70s Caddillac convertable
JifGULj33vabcVpjyo28HfHZuWl6QGZketoHHiaILU2YwI8IwPNDJ9W6uzi3JMhO
