NOT A TA
NOT A TA UltraDork
2/18/22 10:11 a.m.
Just finish the Jag and don't get distracted Frenchy. Unless..... You're really trying to annoy your wife.
frenchyd
frenchyd MegaDork
2/18/22 10:12 a.m.
Saron81 said:
Easy answer is definitely BMC A series.
Lots of easily available parts to make it competitive. Cheap, and plentiful even on this side of the pond.
A 948 BMC engine done to the 9's still has no way to stay with anything else in that group.  Even a 1275 all done won't stay with the back of the field.  The old motorcycle based formula 500 running Norton and JA Prestwitch  engines would give it a dice. But that's about it.
frenchyd
frenchyd MegaDork
2/18/22 10:20 a.m.
In reply to NOT A TA :
You're probably right. It's just that $300 has always been my buying point. While not there •••• yet!    The worst part about it is the condition the bodies pieces are in.  ( and that Saab engine )
Body  work is free for me. I even Have an English wheel  to save all the bondo work.
Saron81
Saron81 Dork
2/18/22 11:58 a.m.
The goal posts are moving, but I have a hard time believing a 150hp engine wouldn't be competitive.
What would your hp goal be with another OHV engine?
A series build by Classic Motorsport
californiamilleghia
californiamilleghia UltraDork
2/18/22 12:39 p.m.
Fiat 850 motors  rev up pretty high with good HP for the size ,
and they are a small motor  .......but they run backwards unless you change the cam !
Sonic
Sonic UberDork
2/18/22 1:54 p.m.
Can you just cut a Jag 2.4 from a MkII in half and have a 1200cc 3cyl?  That would be unique.
Tom1200
Tom1200 UltraDork
2/18/22 2:49 p.m.
In reply to frenchyd :
What you really need to do is just ship the whole project to me as I love two strokes.
frenchyd
frenchyd MegaDork
2/18/22 3:41 p.m.
In reply to Tom1200 :
If you're really serious about it I'll give him a call. But be forewarned it's a mostly use it for patterns type a project. The body is a mess,  no race track damage just garage and storage damage.
    Salvageable because of my English wheel and body experiance.
Tom1200
Tom1200 UltraDork
2/18/22 4:13 p.m.
How is the frame and suspension? Got pictures? Is it currently complete (less body of course)?
clshore
clshore Reader
2/18/22 4:30 p.m.
Are larger motors that have been reduced to 1100 legal?
Triumph Standard 1147 destroked to 1100?
Could use Spitfire 1147 Mk I/II dual SU HS2, headers, loads of cams and other goodies available.
MotorsportsGordon
MotorsportsGordon Dork
2/18/22 5:38 p.m.
Keith  duckworth and  cosworth developed formula jr engines using the engine  in the 59 to 67 Ford anglia. Lotus used this engine in their 18 jr race cars.
pres589 (djronnebaum)
2/18/22 6:39 p.m.
Don't like the sound of them?
https://www.youtube.com/watch?v=WrQSCaUvtcM
Half of the engines mentioned otherwise sound like wet farts compared to these things.
Finish the Jag!
TurnerX19
TurnerX19 UltraDork
2/18/22 8:38 p.m.
In reply to clshore :
Yes de-stroked engines were permitted, but nothing could out perform the Ford 105E in 998CC form as tuned by Cosworth. Also 1 liter Juniors were legally lighter than the 1100CC cars. The first year of the class (before the 105E) Fiat, BMC and DKW engines were pretty equal. De-stroked Triumph and Peugeot were tried.
Noddaz
Noddaz UberDork
2/18/22 9:05 p.m.
Harley engine?
I know it's only a two cylinder, but it does have a distinctive sound.
frenchyd
frenchyd MegaDork
2/19/22 8:57 a.m.
Suitable for a source for patterns. Not useable as is.  The right front took a hard hit.  It's been sitting in a barn up against the wall with bird ( chicken? ) poop causing rust.  The steering rack is too long so it would have caused bad bump steer which tells me the handling probably needs a lot of work to get it right.  It's a Morris Minor  rack  so it would have been extremely simple to narrow.  The fact that wasn't done tells me he wasn't a budding Colin Chapman
frenchyd
frenchyd MegaDork
2/19/22 9:03 a.m.
Finish the Jag!
I really don't like a 2 stroke sound.
  Yes you're right. I must finish the Jag First and then the MGuar  at least I have the important bits for those two. And it's just labor at this point.
frenchyd
frenchyd MegaDork
2/19/22 9:05 a.m.
Noddaz said:
Harley engine?
Aren't used older  Harley's expensive?
frenchyd
frenchyd MegaDork
2/19/22 9:07 a.m.
Yes you're right and the Lotus 18 absolutely blew away front engine Formula JR's
lotusseven7 (Forum Supporter)
lotusseven7 (Forum Supporter) Dork
3/10/22 10:13 a.m.
Just because.
keRj0tHU095pYMILzviLrjjk7TcT4kOOptAclFxlIqKBxaZL9dMGTh0gxTEs0ADj
