I just got this:
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/05/15/1557969817_5168acf9-cfa3-4259-af8f-80d026851d7f_mmthumb.jpeg)
It has a transmission/bellhousing from a 94-95 GT. Apparently, when they made the bellhousing longer, the also changed the angle of the clutch fork, which makes it poke into the left header. Will SN95 headers fit in a Fox chassis? Would you recommend using a Fox bellhousing and a spacer?
No help, but nice car. More details to follow in the build thread right?
I still have some Koni DAs if you need them.
I had a post typed up saying yes they should work. But then I re read and saw a reason why they wouldn't that made sense. Also I too am curious to know more about this car.
EDIT: as far as I know the firewall, floor, frame rails, and k member on a 94-95 car are all the same as a later fox. So if you're using SN headers to clear the SN transmission setup then I imagine they would work.
As much as I would like to make a build thread, this is a case of "bought not built". I decided that I was being too careful with the Fairmont, and that I needed something that I didn't have 22 grand and 30 years of my life invested in. A friend needed this out of his garage, so I took unfair advantage of him, and now I have a car that I can use to learn how to brake later, turn in harder, and just all-around "give 'er hell." It's down a little bit on power compared to what I'm used to, but it was 6 seconds faster on Summit Point Shenandoah than I could run my Fairmont. So far, I've run it one weekend, and I'm at least 2 seconds slower than the 'Mont, but I can see its potential.
grover
HalfDork
5/15/19 11:46 p.m.
Can we talk about that truck in the background? Dent or bump? Looks like a dent.
It's a dent. '79 F-150 Ranger Lariat 2wd, 460, 4v, C6, 9", 3:1, loaded.
thedoc
Reader
5/16/19 4:25 a.m.
Man, I need a friend who just needs a care "gone"!
Sorry, I don't know the answer, but nice score.
I thought I saw a road kill or road kill garage where they hammered the snot out of some headers to make them fit. There wasn't a power loss after the bash, and they fit.
I saw that. They kept hammering until there was a power loss, but there wasn't one. I'd just as soon drop in a header that fit, if I'm gonna have to take it out to hammer the E36 M3 out of it anyway.
I decided to increase the "mine" of the new race car.
![](https://s3.us-east-2.amazonaws.com/prod.mm.com/uploads/2019/06/12/1560392927_8ebf3eed-abe0-4cae-8224-69f93b317dd0_mmthumb.jpeg)
