I'm trying to get a decent weight estimate on my next project. I picked up a Cadillac 500 at a swap meet a couple weeks ago and I want to put it in a first gen (62-65) Chevy II. Here's kind of what I'm wanting to do:
First gen Nova, TH400, Cadillac 500, Ford 9", fiberglass hood, Mustang 2 front suspension, stripped interior with roll cage.
I think it should land me around 2800 pounds, but I would like someone else's guess as well.
Just for the record, I have everything except the Nova, the hood, and the cage laying around.
IIRC 500" Cadillac is around the same weight as a all iron SBC, perhaps a touch lighter with the huge intake replaced with an aluminum one.
Do you know what year the 500 is?
It came out of a 75 El Dorado if I read the numbers right
Smog era then, though desmogged with an intake and good exhaust its still probably a near 300HP 400 some odd ft/lb engine. Should move a Nova quite well with a TH400 and a stock converter to make best use of the low end torque. With the 8.5:1 compression it will probably take light boost quite well....
Doesn't the "500" weigh about a ton ?
In reply to iceracer:
I'm reading ~573 lbs fully assembled with water pump, alternator, and aluminum intake. Bare block is only 210, this was a high tech engine in its time.
So looking at that my guess at around 2800 pounds is close?
tjbell
Reader
8/29/14 3:57 p.m.
Random noob question about the caddy 500. Is it in any way shape or form similar to the bbc454?
2800 is probably close, the 283 models were around 2900-3000 stock from a quick google.
In reply to tjbell:
Other than the quadrajet on top, no. Back then all the GM divisions had their own engine designs, Buick, Olds, Pontiac and Cadillac share a bell pattern(different from the Chevy V8 pattern), that's it.
tjbell
Reader
8/29/14 9:41 p.m.
In reply to Kenny_McCormic:
interesting thanks!
Also, if you want to drop more weight and beef up the front end so it will land a wheelie well, ditch the IFS all together and put a stick axle under there.
I would but I'm not a huge fan of gasser Novas
