fast_eddie_72
fast_eddie_72 UltraDork
12/17/12 8:46 p.m.
I built an engine and welded up coil-overs. I can mount my own tires and rebuild a carburetor. But apparently, installing a water pump is beyond me.
Water pump on the Celica has leaked since I built the engine. Not too bad, just kind of seeping. I got tired of it the other day and pulled it off, cleaned everything up really, really well (and that took a long time!), got a new gasket, put some RTV on it and put it all back together. Now it leaks worse.
What am I doing wrong? Or, rather, I kinda know what I'm doing wrong, but how do I not do it anymore? I get that I'm cranking the bolts down and the RTV is all smooshing out. I saw something on the internet that made it look like I should be putting the RTV on the front cover and the pump, not the gasket. Am I supposed to let it set up some before I put it all together?
I feel like an idiot not being able to do this simple job. Any help is appreciated.
Woody
Woody MegaDork
12/17/12 8:54 p.m.
You may just need the RTV in couple of spots and, yeah it needs to set up for a bit before you assemble it.
Remember: Room Temperature Vulcanizing --> its gotta Vulcanize.
Shaun
Shaun HalfDork
12/17/12 9:00 p.m.
Torque spec? They generally are not held down with much force at all and over squeezing can weak havoc on flat surfaces and therefore mess up the sealing . I miss read the spec on my honda and did it in ft lbs instead of in lbs and it leaked before I got it right.. just a thought.
Tyler H
Tyler H SuperDork
12/17/12 9:03 p.m.
Is it leaking around the shaft? I got three bad waterpumps in a row (same day) for a Corrado VR6 from Napa. R&R requires unbolting and jacking up the front of the engine.
Gearheadotaku
Gearheadotaku UltraDork
12/17/12 9:06 p.m.
Time for the "Right Stuff" Permatex's expensive but invincible RTV.
fasted58
fasted58 UberDork
12/17/12 9:08 p.m.
last one I changed a few months ago was '02 GP, used gasket shellac on gasket and torque wrench w/ no leaky
mad_machine
mad_machine MegaDork
12/17/12 9:10 p.m.
I went through that last year with my ti.. for years I had a slow seep that I thought was the thermostat.. which is right above the waterpump.. last year the pump went.. I replaced it and the seepage stopped.. so all those times I pulled the thermostat and put it back on.. and even replaced it once.. were totally useless as it was not the problem.
Ian F
Ian F PowerDork
12/17/12 9:12 p.m.
Gasket shellac. My new best friend when it comes to this sort of thing. I've never had much luck with RTV sealing a damn thing and I'm a real stickler for torque specs.
fast_eddie_72
12/17/12 9:34 p.m.
No, it's not leaking at the shaft. The water pump is fine. I can see it seeping out where I did a crappy job putting it on.
I know it doesn't need much torque. It uses like eight 10mm bolts. I use the little 1/8 ratchet and kind of plam it when I'm putting it on. I don't think I'm over torquing it. I'm sure it's in inch lbs.
I know some of the front covers on 22Rs aren't true, but I checked this one with a straight edge when I did the motor. Amazingly, it doesn't leak where the cover meets the block, so at least I did that right.
I'm pretty sure I'm just doing a crappy job. If it comes down to it, I guess I could read the directions on the RTV. Kinda hate to thrown in the towel like that, though.
Humm. I'll investigate this gasket shellac. That sounds interesting.
Don49
Don49 Reader
12/18/12 3:28 a.m.
Try Yamabond instead of RTV, and when assembling go hand tight on the bolts for 20 minutes, then fully tighten.
sobe_death
sobe_death HalfDork
12/18/12 4:55 a.m.
Yamabond, Hondabond, Permatex Grey, etc.. They're all the same stuff.
Put it on THIN and smooth, on both surfaces. Then do what Don said above ^^
novaderrik
novaderrik UltraDork
12/18/12 6:01 a.m.
a good gasket doesn't need any sealer when it's sealing one flat surface against another flat surface.
belteshazzar
belteshazzar UberDork
12/18/12 8:59 a.m.
use a gasket and a shelac
OR
a good RTV like permatex grey
whenever i try and use both, i have a problem.
belteshazzar
12/18/12 9:03 a.m.
Tyler H wrote: Is it leaking around the shaft? I got three bad waterpumps in a row (same day) for a Corrado VR6 from Napa. R&R requires unbolting and jacking up the front of the engine.
their Tru-flow brand of water pump has gone from great to crap, and it happened really fast too.
we used to get a handful of warranty claims a month. then a couple months back, all of a sudden we started getting half a dozen every week.
DILYSI Dave
DILYSI Dave MegaDork
12/18/12 9:07 a.m.
Gray stuff, on the WP flange, then put the gasket on, then another layer of gray stuff on the gasket, then install on the cleaned up block flange.
Matt B
Matt B Dork
12/18/12 9:12 a.m.
I had a problem when trying to use RTV on the 86 MR2's water pump. A Toyota dealership parts guy (that I trust) said not to use the RTV, just use the gasket by itself. He was right.
dculberson
dculberson SuperDork
12/18/12 9:47 a.m.
fast_eddie_72 wrote: I know it doesn't need much torque. It uses like eight 10mm bolts. I use the little 1/8 ratchet and kind of plam it when I'm putting it on. I don't *think* I'm over torquing it. I'm sure it's in inch lbs.
Wait... are you using a torque wrench? You probably should, if it's giving you this much trouble.
tuna55
tuna55 UberDork
12/18/12 9:52 a.m.
This, as well as RTV + gasket = no from what I understand, use one or the other.
Woody
Woody MegaDork
12/18/12 9:54 a.m.
tuna55 wrote: This, as well as RTV + gasket = no from what I understand, use one or the other.
Yup.
iceracer
iceracer UltraDork
12/18/12 10:19 a.m.
novaderrik wrote: a good gasket doesn't need any sealer when it's sealing one flat surface against another flat surface.
True !
ransom
ransom SuperDork
12/18/12 10:24 a.m.
Not to threadjack, but perhaps the answer will be pertinent to the OP as well...
If "no" to RTV plus gasket, when would you guys use RTV instead of a gasket?
Only when no gasket available?
Gasket is of questionable construction?
Surfaces aren't smooth/flat?
Always?
tuna55
tuna55 UberDork
12/18/12 11:18 a.m.
ransom wrote: Not to threadjack, but perhaps the answer will be pertinent to the OP as well... If "no" to RTV **plus** gasket, when would you guys use RTV instead of a gasket? Only when no gasket available? Gasket is of questionable construction? Surfaces aren't smooth/flat? Always? ????
RTV over gasket:
When it's relatively permanent
When OEM used RTV
When the surfaces are clean and dry and smooth
When you want to build up height (valley/intake gaskets on domestic V8s)
Gasket over RTV:
When you need to get in there again
When scraping off RTV would wreck the sealing surface (like a carb)
When fluid is around (the PT Cruiser and the van both have tilted transmission pans resulting in a continuous drip over the sealing surface)
When the sealing surface is irregular (exhaust manifolds, although heat would ruin the RTV too)
DILYSI Dave
12/18/12 12:01 p.m.
I won't use RTV with an O-ring (like on a Honda water pump) but with a paper gasket - yep, the gray stuff.
Kramer
Kramer HalfDork
12/18/12 12:32 p.m.
RTV is gasket maker, not gasket sealer.
fidelity101
fidelity101 Reader
12/18/12 12:42 p.m.
Gearheadotaku wrote: Time for the "Right Stuff" Permatex's expensive but invincible RTV.
"I put that E36 M3 on everything!"
1zKTn43QfqYFPMy1yOcHQ8JcINXLFZ92UvzdBAkPrtii02sPDTOQcmNKflQb1OCq
