Woody
Woody MegaDork
8/4/12 5:40 p.m.
...because I just bought my next project: a 2005 Legacy GT wagon that just needs one part...
Photobucket
I'm going to be looking for some advice on this one.
mndsm
mndsm PowerDork
8/4/12 5:41 p.m.
LGT? Already had an EJ25 in it, IIRC. Find a balled up STi and do work.
Woody
Woody MegaDork
8/4/12 6:17 p.m.
Sadly, this one's an automatic, so the STi thing probably won't happen.
singleslammer
singleslammer Reader
8/4/12 6:21 p.m.
Swap!
wbjones
wbjones UltraDork
8/4/12 6:59 p.m.
mndsm wrote: LGT? Already had an EJ25 in it, IIRC. Find a balled up STi and do work.
Woody wrote: Sadly, this one's an automatic, so the STi thing probably won't happen.
get the transmission and the computer AND the engine
Giant Purple Snorklewacker
Giant Purple Snorklewacker UltimaDork
8/4/12 7:03 p.m.
Woody wrote: ...because I just bought my next project: a 2005 Legacy GT wagon that just needs one part...
A BBQ Grill?
Jaynen
Jaynen Reader
8/4/12 7:03 p.m.
You guys make it hard for a guy who lives in an area of the country where space is at such a premium (San Diego)
Woody
Woody MegaDork
8/4/12 7:10 p.m.
This is (hopefully) going to be a pretty straightforward project: find a replacement engine, drop it in and make everything work again.
DaveEstey
DaveEstey Dork
8/4/12 7:36 p.m.
Same engine as the LGT. Pretty sure the tranny is a separate cpu too. I had an auto it was lovely beyond the fact that it never. Ever. Ran right after having a new block put in at the dealership.
1988RedT2
1988RedT2 UltraDork
8/4/12 8:12 p.m.
ACVW swap!
peter
peter HalfDork
8/4/12 8:44 p.m.
Woody wrote: This is (hopefully) going to be a pretty straightforward project: find a replacement engine, drop it in and make everything work again.
Having replaced the engine in a WRX recently... do yourself a favor and triple-check your valve lash before you drop the engine in.
Also, the oil pump will not build pressure with just the starter. Or at least mine wouldn't. If you primed the new pump (I didn't), you might do better.
Woody
Woody MegaDork
8/4/12 9:31 p.m.
So noted.
Ojala
Ojala Reader
8/4/12 10:33 p.m.
I usually put petroleum jelly in the pump to help it prime the first time. Most any EJ engine can work, but there are some extra steps you will need to do to make the AVCS work if you decide to put in an EJ207 or EJ257.
Aaaand....I dont like being a Debbie Downer but a manual swap would eat all the money you saved on this car with a quickness.
carguy123
carguy123 PowerDork
8/4/12 10:46 p.m.
Ojala wrote: Aaaand....I dont like being a Debbie Downer but ...
Hmmm, I must have missed that movie. Was it a follow up to Debbie Does Dallas?
fornetti14
fornetti14 HalfDork
8/4/12 10:49 p.m.
The intake manifold was a bit different on the newer ('05 ish) EJ25's so keep that in mind. If you get a long block make sure you get the right intake manifold with the correct sensor setup.
As others have stated, priming the oil systems requires you to open up the oil pump and pack it with good ol' petro jelly. Crank the starter with no plugs, no coil and no injectors plugged in. Make sure the fuel line is connected though or you'll have a mess. Valve lash is easy in the N/A single cam Phase II motors because it's just a jam nut set-up. I think the dual cam (WRX) motors have puck type lifter shims which are a bitch to do in the car.
Ojala
Ojala Reader
8/4/12 10:53 p.m.
In reply to carguy123:
I saw that again last year, and all I could think about was how awful it was, even by porn standards
Keith
Keith MegaDork
8/5/12 9:33 p.m.
LSx!
Sorry, it's a requirement that this be suggested in every engine thread. I have no useful input.
Brett_Murphy
Brett_Murphy SuperDork
8/16/12 2:48 p.m.
Balled up 2005 Legacy GT in Mass:
http://www.copart.com/c2/onSaleResults.html?_eventId=getLot&execution=e1s2&lotId=21948142&returnPage=SEARCH_RESULTS
Woody
Woody MegaDork
8/16/12 3:36 p.m.
Brett_Murphy wrote: Balled up 2005 Legacy GT in Mass: http://www.copart.com/c2/onSaleResults.html?_eventId=getLot&execution=e1s2&lotId=21948142&returnPage=SEARCH_RESULTS
Thanks but September 12 is a long way off. Of course, that would give me time to figure out how to buy from Copart...
Sonic
Sonic SuperDork
8/16/12 3:46 p.m.
If you need a core motor, a friend of mine has one from his wife's 05 LGT in his garage taking up space, and he is in way north Jersey, not far from you.
Type Q
Type Q Dork
8/16/12 3:49 p.m.
Keith wrote: LSx! Sorry, it's a requirement that this be suggested in every engine thread. I have no useful input.
LSx swaps are so played out.
(Just Kidding)
ClemSparks
ClemSparks PowerDork
8/16/12 3:50 p.m.
Woody wrote: Thanks but September 12 is a long way off. Of course, that would give me time to figure out how to buy from Copart...
In my experience, how you buy from copart involves spending more money than I'm comfortable with (that is, IF you are a licensed salvage dealer).
Woody
Woody MegaDork
8/16/12 3:51 p.m.
That's what I suspected.
dculberson
dculberson Dork
8/16/12 3:56 p.m.
Type Q wrote: LSx swaps are so played out.
OH GOD I can't believe anyone would SAY...
Type Q wrote: (Just Kidding)
[tiny voice]..never mind.
sachilles
sachilles Dork
8/16/12 8:50 p.m.
Cross shop 08+ wrx motor. Same intake setup. Different turbo, that will have to be tuned, but otherwise cheaper to source.
LpOW5VDtvvGHAHbfbfD2sYQAqxHKKYphLEyuFMOCMASyxHgqiHng9xtlUrQgVrIQ
