2 3 4
DionR
DionR New Reader
9/30/24 3:17 p.m.
Noticed in the S197 article that  Terry Fair of Vorshlag commented:
“The S197 has one of the best ABS systems we’ve seen,” Terry says. “That 2011-’14 system is what we swap on other cars.”
https://grassrootsmotorsports.com/articles/s197-ford-mustang-the-best-bang-for-the-buck/
Sounds like another retrofit option.  Couldn't find any details for a swap though.
DionR
DionR New Reader
9/30/24 3:40 p.m.
Of course after posting something, then I find results.
Sounds like the guy likes the S197 module better than the MK60??
https://www.youtube.com/watch?v=JrxyJNUVUGU
At about the 1:29 point he mentions the MK60 and how the S197 unit cycles more aggressively.
rb92673
rb92673 New Reader
9/30/24 4:37 p.m.
We installed a '05 325 MK60 in our Lemons Volvo 745 with stock calipers/ST43 pads.  Just a plain 325 unit, not a M3.  We raced with it at Buttonwillow last weekend.  Going from no ABS to the 325 MK60 was an incredible upgrade.  Thank you to those that contributed to this forum post.
12GS
12GS New Reader
10/1/24 5:13 p.m.
Yes, the S197 ABS is another fairly common ABS install on some platforms, and Vorshlag has made claims that it's better than a MK60. I have not yet seen definitive test results that proved that, and you are unlikely to. The test that proves that one is better than the other requires both ABS systems to be installed in the same car, on the same tires, under the same conditions. Vorshlag has done some testing but they were always using different cars and different tires, so I don't feel that it really proves anything. I personally believe that they're pretty similar in performance, but again, I haven't seen them tested them back to back. They may each have their pros and cons. One pro over the E46 MK60 is that there are no external pressure sensors that need to be plumbed in, but that pro is negated on the E1/E5 MK60 variants.
DionR
DionR New Reader
10/1/24 5:54 p.m.
Thanks!
No argument.  To be clear, I wasn't trying to post it as a "better" solution, only as another option I hadn't heard of before.  Yes, I posted that Terry seemed like it better, but I wasn't meaning to imply that it was better.
My limited research does suggest that the S197 module might have an advantage in price and availablity, too.  Sounds like at least for a time there where motorsport modules for half the cost of an M3 flash, but no idea if they still exist.  At the very least, the MK60 stuff seems to have gotten fairly popular (e.g. expensive) so a different source might be a good thing.
In the end, I don't think I can use either one as I need to feed road speed to my G3 Hemi PCM so I plan to use a MK25 out of a '09 Challenger SRT8 6M and see how it goes.  BTW, no brake pressure sensors need in those either.  The Challenger HCU doesn't have wheel speed outputs so it must be on the CANBus which means I have to keep it all in the same family unless I want to roll my own converter of some type.
DionR
DionR New Reader
10/2/24 1:10 p.m.
Here's some additional info on an S197 ABS swap Vorshlag did.  This is on their S550 LS swapped Mustang.
https://www.youtube.com/watch?v=TovZbkRe2Hc
Sounds like the '11-14 units need the yaw sensor but with that they can be retrofitted.
He mentioned the 302R/302S module from Ford Motorsport being hard to find.  I found posts about them being out of stock, but I also found a Ford website that let me get all the way to paying for one without saying it was out of stock so maybe they made more?  And they seem to be $400-450 for the control module only.  I guess that module doesn't need a yaw sensor to be retrofitted and it has absolutely no TC or stability built into it.
Looks like an '07-09 GT500 unit is another good option.
Here is a thread with some wiring and info.
https://community.drivenasa.com/topic/46617-repost-of-quotford-racing-abs-installationquot/
I guess there is an FP350S module as well?  Looks more expensive and not sure it is an easy standalone swap.
Driven
Driven New Reader
1/18/25 10:17 a.m.
12GS said:
I also recommend using 1/4" brake line from the master cylinder to the ABS pump, and 3/16" brake line from the pump to each wheel.
Has anyone had any issues with using 3/16" brake line inputs instead of the 1/4" recommendation?
My master cylinder uses 3/16 and not sure if I should use 3/16 to 1/4 adapters so I can use the 1/4" line... or just run the 1/4" line
Matthew Kennedy
Matthew Kennedy HalfDork
4/10/25 9:29 p.m.
In reply to Driven :
3/16 lines are totally fine in an ABS-only standalone install. The 1/4 lines were so that when you hit traction/stability control (ie, not pressing the brake pedal), the ABS has to suck fluid through the master and input lines, so you risk cavitation. Standalone installs don't have working traction/stability control, so that isn't a concern. I have 3/16" lines on both of my Mk60 cars with no problem.
theruleslawyer
theruleslawyer HalfDork
4/11/25 9:20 a.m.
Another one I heard about recently is the Delta motorsport ABS.
https://www.deltaabs.com/products/delta-abs-kit
More expensive than a used swap, but cheap for new, motorsport focused stuff. Its cheaper if you order in the UK
https://www.scs-delta.co.uk/product-page/delta-motorsport-abs
PLapping12
PLapping12 New Reader
5/1/25 9:07 a.m.
Hi all,
We recently did this swap into our E46 M3 (it was an 01 so had the early revision and a fire burnt up all the wiring anyways) but it isnt working and we are getting these codes:
005E1F ABS-DSC VIN Different
005E16 ABS-DSC CAN connection to instrument cluster
005E1E ABS-DSC, LWS (Steering Angle Sensor) CAN
005E14 ABS-DSC, CAN connection to DME/DDE (DSC lamp on until igntion reset)
I dont see anything about needing the steering angle sensor and none of the other ones seem like they would effect function.
We confirmed multiple times its not working via some lock ups on a wet and a dry track. Any one have an idea of what the issue might be? Thanks!
2 3 4
iPQrCMKH3IpEHJshQQYUrSDXTE6Mer6KV8z2NwVcGxtXOHjLO5zpuAXJeHMbAV5f
