MrLittle
MrLittle Reader
11/30/16 9:16 a.m.
So the Ion is finally on the road. Drove it two hours home the other day no issues. On my way to work yesterday I noticed a clunking noise on the front passenger side when I let off the throttle.
So scenario goes, driving straight, constant throttle, no issue. When I let off it starts going "clunk, clunk, clunk" with the wheel rotation (going faster = faster clunking, etc). When I turn left at constant throttle I feel the clunk more than going straight.
I'm thinking it's either wheel bearing or axel? Is there something I'm missing or can do to narrow it down to one or the other?
captdownshift
captdownshift PowerDork
11/30/16 9:21 a.m.
Check the motor mounts if it only does it when you let off the throttle.
MrLittle
MrLittle Reader
11/30/16 9:28 a.m.
In reply to captdownshift:
Do you think a motor mount being bad would make the clunk continuously when I'm off throttle or just a single clunk or so when I let off initially?
captdownshift
11/30/16 9:41 a.m.
With it being constant, it's not likely a mount. Does it do it more when turning to one side versus the other?
Streetwiseguy
Streetwiseguy PowerDork
11/30/16 9:45 a.m.
Tighten the wheel nuts?
MrLittle
MrLittle Reader
11/30/16 9:55 a.m.
In reply to Streetwiseguy:
Haha tried this. I just did the brakes so it was a real thought.
11/30/16 9:56 a.m.
I was thinking motor mount until you said it was constant and varied with wheel speed. One "clunk" per lift-off could be a motor mount.
I'm thinking CV joint or wheel nuts. I had the same noise from the back of my Samurai once when the wheel nuts were just a slightly loose.
NEALSMO
NEALSMO UltraDork
11/30/16 10:21 a.m.
Sway bar links and ball joints can make that type of noise as you load and unload them. Both are easy enough to check with the car jacked up and wheels off the ground.
outasite
outasite Reader
11/30/16 11:28 a.m.
MrLittle wrote: In reply to Streetwiseguy: Haha tried this. I just did the brakes so it was a real thought.
Did you tighten/torque the caliper?
jstein77
jstein77 UltraDork
11/30/16 11:45 a.m.
+1 on the CV joint.
TGMF
TGMF Reader
11/30/16 12:19 p.m.
My guess is Worn engine mounts, that in turn caused damage to CV joints. Issue is aggravated when engine torques on acceleration and then drops back into place off throttle.
Antihero
Antihero Reader
11/30/16 12:30 p.m.
My guess is cv joints
curtis73
curtis73 PowerDork
11/30/16 12:33 p.m.
Motor mount would absolutely cause multiple shakes. 60s GM boats had this problem. The trans mount would separate and when you did a certain thing (could be turning, decel, accel) it sounded like there was a drummer with two rubber mallets under the seat.
The CV joints are not nice smooth things like many think. There are pretty intense forces every 120 degrees as the bearing speed peaks and falls on each knuckle. Add to that the harmonics carried through the differential and it can make for some wild vibes.
7PC5lHNjFGLKECnxhpVCij3smQ9mu1wPNz01yCYUOh8QgdYtZPJBs7bUTppOuM6l
