D2W
D2W HalfDork
12/1/17 12:13 p.m.
Is a small block chevy starter bolt Gr5 or Gr8?
12/1/17 1:30 p.m.
No idea, but I'd be surprised if grade 5 didn't hold up there.
fasted58
fasted58 MegaDork
12/1/17 1:55 p.m.
The factory starter bolts are knurled near the threads. Factory wouldn't do this if a regular 3/8"-16 bolt would do... beancounter stuff. Stick w/ OEM or Dorman, they're cheap enough.
D2W
D2W HalfDork
12/1/17 3:43 p.m.
I have a situation where it is no longer possible to use factory bolt. Anyone know why they are knurled. Cost is not the problem.
fasted58
fasted58 MegaDork
12/1/17 3:55 p.m.
In reply to D2W :
Knurl fits the counterbore in the block. Alignment I would think but also think of the torque on the starter.
Streetwiseguy
Streetwiseguy UltimaDork
12/1/17 6:43 p.m.
The knurl is purely for alignment.  If you are smart enough to compensate for that, a Grade 5 should work.
NOT A TA
NOT A TA Dork
12/1/17 9:28 p.m.
As Streetwiseguy posted, alignment. Be aware if you're not familiar with SBC starters you may need to shim and checking first can save you from breaking the snout off.
fasted58
fasted58 MegaDork
12/1/17 9:39 p.m.
and use the starter support bracket
bwszjs9QYSZFHxUdrn24r060YGhtba9wD9xK6VX96FswiZFoLRJyYc3CKiRYDJqP
