ronholm
ronholm HalfDork
6/26/13 5:19 p.m.
I am hoping you can help me diagnose this problem before I senselessly throw more parts at it...
This isn't normally something I struggle with... but... well... I am hot and tired...... and well... enough already...
Bought the car with a softish brake pedal.. It stopped, but was concerning... So I replaced the master cylinder, new pads, rotors, ect.. all looked good with the calipers, ect.. No problems.. It bleeds fine and fluid was flushed. Seemed to work great... For a while...
.. The rears are not ice cold but I think the problem is in the front... They don't bind up completely.. just enough to be really annoying, and get things HOT!.
After the first time the brakes stuck I did new rubber lines on the front
That didn't help so I went through and unplugged all the ABS nonsense... One of the rings is missing from a front axle so I figured that could hurt nothing... Flushed fluid again and no problems at all with a vacuum bleeder.....
Normally stuff like this isn't over my head.. but... geez... Before I just throw more parts at it....
What would ya'll try next????
iceracer
iceracer UberDork
6/26/13 5:57 p.m.
Caliper slides and or pistons corroded.
Kenny_McCormic
Kenny_McCormic Dork
6/26/13 6:07 p.m.
Do the sliders ride in rubber sleeves? Pull em out, there will be rust. You can also get rust under the SS shims on the caliper/bracket causing the pads to bind
Cone_Junky
Cone_Junky Dork
6/26/13 6:15 p.m.
Mis-adjusted master cylinder? If the linkage is adjusted too tight the slight expansion from heat will cause the master cylinder to slightly actuate and drag the brakes.
Vigo UltraDork
6/26/13 11:19 p.m.
Get it to drag, loosen the nuts holding the master cylinder to the booster, and see if it still drags. should be able to do this on the road with a 13mm wrench/socket. Just a quick/easy check to rule out anything on the booster/vacuum/pedal linkage side.
AngryCorvair
AngryCorvair PowerDork
6/27/13 3:24 p.m.
my work here's done. (ie the previous posters hit everything i would've)
ronholm
ronholm HalfDork
6/27/13 4:49 p.m.
a maladjusted master sounds like it most likely culprit! I had the feeling being hot, tired, and a bit ticked off about melting the new brakes was causing me to overlook something...
It was sticking when I parked it and free as could be this morning when I checked..
I will take a 13mm wrench and hit the road to confirm a little bit later!
THANKS!
si8dMIzw079N23Ive1q6gieKFXws5eRARR06n5OnxiFtCIYsNkOTdLB0MCjhKZDZ
