Grtechguy
Grtechguy SuperDork
1/19/09 7:55 p.m.
If I have an engine with the following specs, how many PSI should my guage read? or am I not providing enough information?
Displacement: 171.00 ccm (10.43 cubic inches)
Engine type: Single cylinder
Stroke: 2
Power: 15.00 HP (10.9 kW)) @ 7500 RPM
Compression: 6.8:1
Bore x stroke: 66.0 x 50.0 mm (2.6 x 2.0 inches)
RobL
RobL New Reader
1/19/09 8:02 p.m.
If your compression is 6.8:1 - a compression test should read about 100PSI on a 4 stroke. But it's a 2 stroke so I'm not sure.
Nashco
Nashco SuperDork
1/19/09 9:11 p.m.
Grtechguy wrote: If I have an engine with the following specs, how many PSI should my guage read? or am I not providing enough information?
Which gauge?
chaparral
chaparral New Reader
1/19/09 9:13 p.m.
6.8:1 is the ratio of the volume of the cylinder when the last port closes to the combustion chamber volume.
You're looking for at least 14.7 PSI x 6.8, so 100. You should get somewhat higher numbers if it's a reed or rotary valve engine due to crankcase compression.
chaparral
1/19/09 9:14 p.m.
What engine is this?
Grtechguy
Grtechguy SuperDork
1/19/09 9:15 p.m.
It's a Yamaha 175cc still mounted in the '80 DT175mx
Grtechguy
Grtechguy SuperDork
1/19/09 9:16 p.m.
Which gauge?
The one I use to get compression readings. reads 0-250psi. screws in the spark plug hole
chaparral
1/19/09 9:16 p.m.
100 PSI.
If you want more, check the crankcase seals and put in some new reeds.
RXBeetle
RXBeetle New Reader
1/19/09 11:04 p.m.
dynamic vs static compression ratio is the curve ball here. This may help: http://www.dirtrider.net/forums3/showthread.php?t=152854
4KpExfb9prAZp2g9dO4gQtyBV926mv0ZH0ELJn9mHgwRiuWH1RqVQUm37sYNarWt
