P71
P71 SuperDork
5/9/10 7:36 p.m.
The Miata broke! We drove it all weekend, put about 250 miles on it. Audra and I got 8 autocross runs each with it this morning. On the way home, 3 miles from home it quit with no warning and won't restart. It rocks and rolls like it has compression but it won't even try to to kick over. We had to have it TOWED!!!
Stupid flipping Miata!
DeadSkunk
DeadSkunk Reader
5/9/10 7:40 p.m.
I'll give you a hundred bucks for the damned thing, sight unseen.
grimmelshanks
grimmelshanks Reader
5/9/10 7:41 p.m.
are you ranting or looking for a cause?
Wowak
Wowak SuperDork
5/9/10 7:43 p.m.
DeadSkunk wrote: I'll give you a hundred bucks for the damned thing, sight unseen.
$150.
Jensenman
Jensenman SuperDork
5/9/10 7:52 p.m.
$150.
$175 and a case of Stella Artois.
Lesley
Lesley SuperDork
5/9/10 7:53 p.m.
$175, and I'll throw in a 1992 Mazda 323.
porksboy
porksboy Dork
5/9/10 7:55 p.m.
$176.00 a button, a Lee Oscar harmonica, a burned wooden match, and a whisker I found in the hallway this morning from my cat. Thats all that is in my pocket at the moment.
P71
P71 SuperDork
5/9/10 8:04 p.m.
Lolz! Sorry buckos, not selling my hardtop-equipped, Rota-shod Miata for any amount of loose change and pocket lint. ;)
I'm fishing for ideas on where to look first when I try to fix it tomorrow. I'm 95% sure it's not the timing belt. It ran like champ all damn weekend too!
fastmiata
fastmiata Reader
5/9/10 8:13 p.m.
Describe what it is doing or not doing. Is the fuel pump running? Check to see if you are getting any spark(my guess is the coil packs). Good luck and if you cant get it running, I will take it off your hands for $200.00.
porksboy
porksboy Dork
5/9/10 8:16 p.m.
I just checked my other pocket and found $25.00 that I will add to my generous offer.
Sorry I have nothing constructive to add other than fuel, spark all at the correct time.
friedgreencorrado
friedgreencorrado SuperDork
5/9/10 9:11 p.m.
Maybe it's not stupid. Maybe it's clairvoyant. Perhaps somewhere in that last three miles, a drunk teenager in a Civic (or a harried soccer mom in an SUV) ran a stop sign through an intersection. One that would have been full of You & Audra & Rotas & Miata if it had not kindly decided to deposit you safely upon the shoulder.
If it fires up tomorrow, I was right. And if it doesn't..I'll take it for the towing bill.
joey48442
joey48442 SuperDork
5/9/10 9:22 p.m.
porksboy wrote: $176.00 a button, a Lee Oscar harmonica, a burned wooden match, and a whisker I found in the hallway this morning from my cat. Thats all that is in my pocket at the moment.
You saved the whisker?
Joey
unevolved
unevolved Reader
5/9/10 9:48 p.m.
Cam position sensor connection? I've had that happen to me on a car or two and give the same symptoms.
Wowak
Wowak SuperDork
5/9/10 10:50 p.m.
Everything in my house for the Miata.
grimmelshanks
5/9/10 10:58 p.m.
whats in your house??
Wowak
Wowak SuperDork
5/9/10 11:05 p.m.
grimmelshanks wrote: whats in your house??
probably mold.
Keith
Keith SuperDork
5/9/10 11:17 p.m.
Does it crank? "Doesn't try to kick over" isn't clear to my brain.
P71
P71 SuperDork
5/9/10 11:34 p.m.
It cranks (hit the key, starter goes whiiiirrrr, engine goes boink-boink and shakes/rattles/rolls, nothing tries to actually "fire" though).
Apexcarver
Apexcarver SuperDork
5/9/10 11:47 p.m.
check for spark, check for fuel pressure?
friedgreencorrado
5/9/10 11:53 p.m.
P71 wrote: It cranks (hit the key, starter goes whiiiirrrr, engine goes boink-boink and shakes/rattles/rolls, nothing tries to actually "fire" though).
Cranks, but no pops from the lump? Try just turning the key to "on" without turnint all the way to "start" (let the lil' lights flash, they won't steal that much voltage). You should be able to hear the fuel pump pressuring up. If not, well..there's a start.
Apologies in advance if you've already done this.
ZOO
ZOO Dork
5/10/10 5:26 a.m.
Sounds like the coil packs -- we had the same issue on my wife's. Timing belt isn't a bad guess, either. Are the cams turning when the engine cranks (look through the 710 access hole on the valve cover)?
racerdave600
racerdave600 Reader
5/10/10 8:37 a.m.
If it tries to crank it probably isn't the timing belt. It would simply spin on endlessly if the timing belt broke. I would start with the coil pack first, but Keith would probably be better equipped to say that. Mine did do that once and it was the coil pack though.
Keith
Keith SuperDork
5/10/10 8:59 a.m.
There are a few things that can cause a Miata to just stop. It's almost impossible to stop a Miata from cranking, though. That's a pretty fundamental ability.
Coils tend to go individually, which makes the car run like a tractor but won't kill it. Fuel, no spark on two cylinders (1-4 or 2-3).
A break in the wires at the cam angle sensor will kill 'em dead like this. If that's the case, no fuel, no spark.
Main relay. More typically, this is a "the car was running fine until I turned it off, now it won't fire" kind of failure. I haven't heard of one cutting out when the car was running. The main relay is in the fusebox under the hood, you might be able to see burned contacts if that's the problem. No fuel, no spark, no power on any white wires with red stripes.
Fuel pump failure is pretty obvious. No fuel, spark.
Timing belts tend to break when pulling away from a start or starting the car. The car might crank funny. Pull the oil fill cap and watch the exhaust cam as you crank. This one isn't common, but it can happen.
Sofa King
Sofa King Reader
5/10/10 9:26 a.m.
You do have gas ...right? Wouldn't be the first time that after a fun weekend, the gas guage was ignored.
Kia_racer
Kia_racer Reader
5/10/10 9:44 a.m.
Sofa King wrote: You do have gas ...right? Wouldn't be the first time that after a fun weekend, the gas guage was ignored.
Quoted for truth! Been there done that, boy did I feel stupid.
kUuPV0tnxWoW4Q40GFdJ48cWOl27j61ookrr8TvZGrJfgFUIHM5OXfffew39ZLLQ
