carguy123
carguy123 Dork
5/6/09 9:22 p.m.
Can someone tell me what the secret code is for determining if a Subie has an LSD?
RexSeven
RexSeven HalfDork
5/6/09 9:31 p.m.
Oh, I thought you meant this kind of Subie-Q:
carguy123
carguy123 Dork
5/6/09 10:21 p.m.
Now that's just sick.
Appleseed HalfDork
5/6/09 11:21 p.m.
NOSSSSS!
carguy123
carguy123 Dork
5/7/09 10:31 a.m.
No one knows the secret decoder ring setting to see if a car has an LSD?
Well does anyone know which models, other than the WRX, probably came with an LSD?
curtis
curtis New Reader
5/7/09 10:41 a.m.
Appleseed wrote: NOSSSSS!
HAHA BOOOOM!
ValuePack
ValuePack HalfDork
5/7/09 12:50 p.m.
carguy123 wrote: Well does anyone know which models, other than the WRX, probably came with an LSD?
Upmarket Foresters(S, XS, XT), '00 and '01 Impreza 2.5RS.... RRRR, I used to know all this. '80s models typically had LSD stamps on ID tags. Maybe I'll take a run outside to look at the wife's Forester and see if it boasts of it's junk in the trunk.
carguy123
carguy123 Dork
5/7/09 1:43 p.m.
Thanx, that helps.
Woody
Woody Dork
5/7/09 2:53 p.m.
Swapping something? We need details...
wawazat
wawazat New Reader
5/7/09 3:47 p.m.
All the AWD SVX had a VLSD their R-160 in 3.545:1 ratio.
carguy123
carguy123 Dork
5/7/09 5:29 p.m.
Woody wrote: Swapping something? We need details...
Working on an engine for a kit car.
Didn't the SVX also have the 3.3 H6? And wawazat are you saying only the R160 had the VLSD? What about the tranny section, that's all I'll be using.
RexSeven
RexSeven HalfDork
5/7/09 5:57 p.m.
carguy123 wrote: Didn't the SVX also have the 3.3 H6?
Yes, the SVX had the EG33, a 3.3L H-6.
carguy123 wrote: And wawazat are you saying only the R160 had the VLSD?
I think all SVX's had the VLSD.
carguy123 wrote: What about the tranny section, that's all I'll be using.
Not sure what you mean by this. All I know is all SVX's came from the factory with autotragics. Manual swaps are possible, though.
carguy123
carguy123 Dork
5/7/09 6:18 p.m.
I'm using the Subie engine in a middie configuration as a 2WD so I'll be tossing the R160. I really need a 5 speed cause so far I haven't found a way to lock out the rear drive section on a 6 speed.
wherethefmi
wherethefmi HalfDork
5/7/09 6:53 p.m.
wrx is open diff for the front afaik. i would check on nasioc.com if the info isnt there...well ehh good luck
wherethefmi
5/7/09 7:02 p.m.
it will also make a difference what year and displacement wrx its coming out of
carguy123
carguy123 Dork
5/7/09 10:41 p.m.
I am seriously hoping you are wrong. Since FWD cars usually have more need of an LSD than a RWD and since Saker uses the Subie I'm hoping that means at least the WRXs have a front LSD.
I really didn't want a WRX motor tho, but I guess I can buy a tranny separately and put it on my donor car motor.
friedgreencorrado
friedgreencorrado Reader
5/7/09 10:55 p.m.
HAHA BOOOOM!
"..duuude! It was running great before that, even though I heard one of the hoses hissing a lil' bit..."
Apologies to carguy for not really being able to help.
InigoMontoya
InigoMontoya Reader
5/7/09 11:26 p.m.
05+ legacy GTs have them in the back, none in the front though.
STi's get the fancy front diff, makes them more special than plane jane wrxs
wherethefmi
5/8/09 12:37 a.m.
I think that aftermarket front diffs exist......and it does, cusco makes it.
http://forums.nasioc.com/forums/showthread.php?t=1072122&highlight=front+diff
I hope that helps, so in theory you could remove the driveshaft to the rear and have all the power go to the front, though I'm not sure how the center diff will react, I think there's 3...stupid time for me
"OBX makes a 5mt front lsd for >$500"
carguy123
carguy123 Dork
5/8/09 9:29 a.m.
wherethefmi wrote: I hope that helps, so in theory you could remove the driveshaft to the rear and have all the power go to the front, though I'm not sure how the center diff will react, I think there's 3...stupid time for me
Here's how you handle the center and rear diffs
http://www.bremarauto.com/subaru_transaxle_conversion.htm
Strizzo
Strizzo Dork
5/8/09 10:43 a.m.
from what i remember from when i was looking at them, any wrx or legacy/outback with the winter weather package (heated seats, wiper area) came with a rear lsd, and (maybe?) a vlsd center diff, but im thinkin not
carguy123
carguy123 Dork
5/8/09 11:08 a.m.
Did Subie not put more than a Viscous Limited Slip in any of the fronts? Viscous is better than no LSD, but I'd have guessed they'd have put the good stuff up front where it would do the most good.
Can't wait for the weekend when I'll have time to join & post to nasioc and then get flamed unmercifully.
Woody
Woody Dork
5/8/09 11:13 a.m.
Strizzo wrote: from what i remember from when i was looking at them, any wrx or legacy/outback with the winter weather package (heated seats, wiper area) came with a rear lsd, and (maybe?) a vlsd center diff, but im thinkin not
I have a 2004 WRX with the Winter package. As far as I know, the package was just heated seats, mirrors and wipers, plus rear spoiler and sunroof. I'll try to find the window sticker for the full details.
wherethefmi
5/8/09 11:52 a.m.
go to the local subforum. the txic is a bunch of pretty cool dudes
jwx
jwx New Reader
5/12/09 2:56 p.m.
No Subaru, aside from the STi, had a front limited slip of any kind.
PCZJQeOsmuXbhvQLAHI24KQJHFnLElxfBUw3m5RwigVhzlT7nwgjKK1sgss2w61U
