kcbhiw
kcbhiw Reader
9/10/08 9:41 a.m.
From the early turbocoupes (85-86) using the Garrett T03 turbo, where might I find the oil restrictor? Is it the 90* fitting at the top of the cartridge (the porting looks a bit large, IMO) or is it located elsewhere in-line witht he oil feed?
egnorant
egnorant Dork
9/10/08 5:44 p.m.
I don't believe there is a separate part that can be called a restrictor. Stock parts are adequate. Are you getting smoke or oil in the intake? Some folks at turboford have done some work with restrictors for different bearings or other considerations.
http://www.turboford.net/ubb/ultimatebb.php
Bruce
kcbhiw
kcbhiw Reader
9/10/08 10:33 p.m.
Thanks Bruce. The turbo is going on the Challenger, so no smoke....yet. The piping size that I have is small diameter-wise, but from various turbocharger installations I've come across, it seems there was something else to limit oil pressure to the turbo. I'd like to avoid popping a turbo the day before the event :).
DILYSI Dave
DILYSI Dave SuperDork
9/11/08 8:10 a.m.
Kev - I got an oil inlet restrictor for my T25 from ATP Turbo.
Also, in a pinch I have used a globe valve and pressure gauge from grainger to regulate oil pressure to a turbo. Not ideal, but it worked.
0wfPPxmAXqiXMW6wld04mCurxZ93dw109wnd38FhD3ydNV1hOc7cMJacPgmw35yK
