grover
grover Dork
10/10/22 7:25 p.m.
My father has a decent drag racing following- mostly ford guys. They spend mucho money on motors and I'm sure this could help.
bobzilla
bobzilla MegaDork
10/10/22 8:16 p.m.
In reply to grover :
Send them my info. I'm always willing to talk shop. Although a lot of those guys tear down and rebuild throughout the year too. But if I can help I will.
Mr_Asa
Mr_Asa UltimaDork
10/10/22 8:38 p.m.
maschinenbau said:
In reply to Mr_Asa :
What oil do you plan to use? The dealer did my first 2 changes with 0W-20 but I'm thinking about moving to 5W-30 since I'm in a warm climate and starting to do track days.
Figured 0W-20, I'll go from there with Bob's help.  Not planning on doing any track days anytime soon.
Brett_Murphy (Agent of Chaos)
10/10/22 8:42 p.m.
bobzilla said:
In reply to Brett_Murphy (Agent of Chaos) :
The answer is complicated. It's not for everyone.
Thank you for taking the time to answer my question so well.  Would the Subaru 2.5 turbo ringland failure show up in these tests? That's about the only engine I have known for being wonky.
03Panther
03Panther PowerDork
10/10/22 9:10 p.m.
I was gonna quote his answer to ya, to say "well said", but I'll saw it here! Great answer.
bobzilla
bobzilla MegaDork
10/10/22 9:10 p.m.
Maybe? It really depends on if the ring lands are failing because the rings are too tight and causing excessive wear, overheating the top of the piston causing it to break or just metal fatigue that after x number of cycles let's go.
if it's the former you'll see signs of the ring wear in elevated chromium and iron and theoretically should see that excess heat in the oil properties via the oxidation and a rapidly depleting base. If it's the latter everything will look normal until the day it pops.
to be honest I don't know what the failure mode on those are.
I read my responses to the "should I do this" and realize I'd make a terrible salesman. Good thing this isn't feeding my kids (that I don't have). They'd starve lol
bobzilla
bobzilla MegaDork
10/10/22 9:13 p.m.
Depending on the 0w20 some do handle track time well. Just did one on a Mazda 2 with track time and it held up really well.
03Panther
03Panther PowerDork
10/10/22 9:24 p.m.
I value honesty over salesmanship, all day long. Others do as well. And honestly has its own rewards. Sometimes even financial. Though often not. Sadly.
bobzilla
bobzilla MegaDork
10/10/22 9:37 p.m.
I get to keep doing what I enjoy and hopefully that helps others.
10/11/22 11:14 a.m.
It might not fit my use case, but your honesty makes me much more likely to suggest your services to friends that could benefit from your services.
3urAnl9gPGkQbYLYr5oEFf0QEddorhzkHU5JAgNrTuxS2RKNKRdaOLTxOA9JW1UU
