NOHOME UltraDork
2/16/15 10:06 a.m.
The Miata chassis donor that I am using does not have AC. However, in the interest of keeping life simple, my intentions are to source an AC system for a 96 Miata and use it. I assume it plugs in under the dash no problem.
This then leaves me with the pump. I have a ford 302 with an AC pump. Should I take advantage of the fact that this thing already is bolted to the engine and adapt to work with the Miata system or easier to make a mount for the Miata pump?
Any other caveats to be aware of? What year Miata came from the factory with 134A?
BoxheadTim
BoxheadTim UltimaDork
2/16/15 10:13 a.m.
With ac systems I'm always assuming that the compressor size has to be matched to the rest of the system so I would try to source and fit a Miata compressor.
2/16/15 10:35 a.m.
We use the GM compressors on our LS swaps. The plumbing is a challenge, but the system works just fine. It's not like trying to match a PS system.
I'd recommend sourcing the parts from a 1994-97 Miata. Some Miatas came from the factory with the evaporator in place, but the Canadian cars didn't. Not sure where your shell came from.
viIAORitjE0WMU4Q8j2XUFrOlnBLwuWwNnPbqNfkxbD7o9qOIC22E9Ry3kEvJFnh
