5/11/17 4:00 p.m.
[Editor's Note: This story ran in the April 2017 issue of Grassroots Motorsports. Some information may be different today.]
Meet our expert:
Collin Gyenes
Techtonics Tuning
 (503) 843-2700
Collin Gyenes has been servicing and building fast Volkswagens with Techtonics Tuni…
TR7
TR7 New Reader
5/11/17 11:14 p.m.
On the suspension side you can put in the Audi TT spindle to get some better geometry, just flip the tie rod around. Partsgeek also has TT lower control arms ($88 each!) loaded with the above mentioned bushings and moog balljoints. That will gain some camber adjustability. And if you are doing all this, it's likely that changing the struts is in the plans anyway, and surprise! TT struts will fit, and also provide a convenient mounting point for the swaybar mount lost swapping to the updated control arms. Just add a universal 18" ball end sway bar endlink from white line. (No need to swap to a TT sway bar). If lowering is in the plans, be aware that there is a short and long version of the bumpstops for the standard and sport cars. All GTI brake gear will fit, and fit under 15" wheels. Larger rotors will fit with TT caliper bracket, but larger wheels are needed. The rear end can be stiffened up on the cheap with some springs from the Jetta sedan or wagon.
smokindav
smokindav Reader
5/12/17 5:37 a.m.
The MkV and newer are much better cars - please do a write up on them.
jonnyd330
jonnyd330 Reader
5/14/17 7:46 a.m.
smokindav wrote: The MkV and newer are much better cars - please do a write up on them.
But thr mk4 is better looking
einy
einy Reader
5/14/17 7:20 p.m.
I second this request ... MkVI please!
Dootz
Dootz Reader
10/18/19 12:38 a.m.
Guys, the Mk6 writeup is literally on the sidebar of this page:
https://grassrootsmotorsports.com/articles/tech-tips-2010-14-vw-gti/
Creammotors
Creammotors
10/18/19 1:52 a.m.
I have an 04, automatic, 4dr, 2.0! Timing belt busted on me. I am looking for some options. I may go new motor, but uncertain. I am looking for some ideas/options!
aw614
aw614 Reader
10/18/19 7:22 a.m.
It brought us a generation of paint eating stance bro VW owners lol.
GTI_2032
GTI_2032
6/29/20 6:31 p.m.
In reply to TR7 :
Does the lower control arm change require the TT spindle or can the VW spindle be used with the TT lower control arm?  Would be nice to have some adjustment on camber.  Thanks!
GTI_2032
GTI_2032 New Reader
6/29/20 6:35 p.m.
Not sure i understand all of the hate for the MK4 GTI.  I have a 20th anniversary edition.  I think it is a very nice car.  Fun to drive.  Even more fun to drive after some OEM+ mods to suspension and engine.
I have ridden and driven in a MK7 GTI.  Very nice car, for sure.
TR7 (Forum Supporter)
TR7 (Forum Supporter) Reader
6/30/20 8:49 a.m.
GTI_2032 said:
In reply to TR7 :
From what I remember, you can use the TT lower control arm and VW ball joint with the VW spindle. This will gain you some camber, maybe 1 degree on its least aggressive setting? You cannot however use a TT spindle with a TT ball joint and VW control arm. Technically I guess you can make it work, but its awful. The ball joint doesnt really fit and you end up with a lot of positive camber.
Growl_R
Growl_R New Reader
2/12/22 1:39 p.m.
yes
collins_dan
collins_dan
8/7/22 9:46 a.m.
Add a turbo to the VR6 and it will go like mad. The engine itself can take well over 400hp at 10 psi, but mounts need upgrading and be careful on standing starts.
8/7/22 10:53 a.m.
In reply to collins_dan :
 But the VR6 sounds like poo and is heavy.
Paul_VR6 (Forum Supporter)
8/7/22 3:31 p.m.
Get. Out.
mk4 make good parts cars unless you love the smell of crayons.
xr3B1Msdh1CgHN3tylYZylGJx2g3xgBvcewOjICmolHCYXSWu9MVTFkGtqMF6pmP
