BBsGarage
BBsGarage HalfDork
2/22/12 4:10 p.m.
I have this rather old VW (1500 or 1600 not sure yet) engine that I am looking to fire up after its been sitting for an unknown period of years. I pulled the plugs and sprayed wd40 into the cylinders and when I drained the oil the very first bit of oil that came out was rather grey. The remaining was black as I expected.
Is this something to be concerned about? Im guessing its some water from condensation as it was stored in an open barn for some time before I had it in my garage.
Dr. Hess
Dr. Hess SuperDork
2/22/12 4:27 p.m.
Yeah, the gray was water mixed with oil. Sure you don't have a BHG? It certainly can't be a "good" thing, but give it a try. It probably wouldn't hurt to pull the oil pan and inspect, but my ACVW-fu is weak.
mad_machine
mad_machine SuperDork
2/22/12 4:29 p.m.
not a pan to inspect on a Type 1.. just an inspection plate where the oil pickup is.
I would do a flush with some cheap oil.. maybe disconnect the ignition and crank it a lot to get the pressure up.. and then dump and refill with something decent before starting
SyntheticBlinkerFluid
SyntheticBlinkerFluid Dork
2/22/12 4:50 p.m.
It sounds like at one time that was using leaded gas, lead deposits end up in the bottom of the oil pan.
I would pull the pan (sump cover on a VW) and scrape the rest of the deposits out.
Nothing Major to worry about.
BBsGarage
BBsGarage HalfDork
2/22/12 5:22 p.m.
thanks, I was planning on doing the flush thing anyway since its been sitting so long. I also drained the oil thru a paper towel to see if there are any tell tale shavings. Havent looked at it yet.
bludroptop
bludroptop SuperDork
2/23/12 3:28 a.m.
There's a screen behind that inspection plate - what passes for an oil filter on these motors. Clean the screen, give it a flush and fire it up.
Absent some prior damage, you should be fine. These things aren't fussy.
Post the serial number and we can tell if it is a 1500 or 1600 - at least originally. Many were upgraded over time, as a piston and jug replacement without splitting the case was a common backyard 'engine rebuild'. Did a few myself....
9tf8bLRQ1dIy6Zt3gENB6zfwOkN3L1AnGVg4QFLuKUGpdDc4Rw4y2yCKZJtgNCFV
