3 4 5
CyberEric
CyberEric SuperDork
3/8/25 2:41 p.m.
Good to know the MPGs these can get on the highway. Seems like a super useful vehicle.
John Welsh
John Welsh Mod Squad
3/8/25 6:11 p.m.
In reply to CyberEric :
My mpg for the roughly 65 miles trip of towing this Prius back home = 17.4
All flat, 2 lane roads with a couple of small town slow downs and just a little "in-town" driving.
On page 4 of this thread you can see that 3 years ago I towed a Prius with this van and got 17.1 mpg -- the same!
dculberson
dculberson MegaDork
3/10/25 10:52 a.m.
We're around 100k miles on our 2016 now. Still a great van. I've had to do the thermostat, rear brakes, and three of the climate control actuators. Lately the gas milage has tanked and I need to dig into it to figure out what's going on. (usually ~26-27mpg on road trips, this latest trim yielded about 19mpg. Getting 17-18mpg in town.)
John Welsh
3/10/25 11:26 a.m.
I've been wondering what the 80k service should be?  I'm still on original fluids and I suspect that it would be wise to update trans fluid, especially with a history of towing.
Otherwise zero work other than oil changes to this point.
I do have a airbag light on which code reads as driver's seat side airbag.  I found some online that implies that the power seat mechanism pinches a wire.  Suggestions are to break down seat a bit and replace wire harness or break down to wire splicing.
My driver seat is showing wear so I'm considering a JY, fresher seat replacement.
I also have a windshield crack that has become quite intrusive.  Plans for its replacement when the weather warms.
John Welsh
5/9/25 8:09 a.m.
John Welsh said:
At what age/milage did the trouble start?
I'm accepting this Mopar van for what it is, a middle quality vehicle,  but I'm hoping to offload it around 100k and expecting to be reasonably trouble free to that point.  At this rate I have 5 more years.  I hope then this 7 year old vehicle with 100k miles will be worth $10k. I bought for $15k ($17k+ with tax and tires right away)
I'd love to see a sub $2k per year combined depreciation and maintenance cost.  Factoring in $7k depreciation in 6 years, that leaves me $5k to put toward repairs in the next 5 years.  Anything less is winning.
On page 4, back in June 2021 I wrote the post above about hoping to off-load at about 100k, before the problems settle in.
Here I am, now at 80k and my first check engine light that points to thermostat.  Youtube videos show me that a thermostat change shouldn't be hard.  Its a plastic elbow and though mine is not leaking, I chose to upgrade to the metal elbow, $20 part.
Windshield recently replaced.  Airbag light still not addressed.
Here's a picture from March of 2025
Ian F (Forum Supporter)
5/9/25 3:10 p.m.
My 2017 is at 149K and hasn't had too many issues.
Had the EVAP System Integrity Module (ESIM) fail at 126K, but that was an easy DIY fix. Apparently this is a common EVAP fault for the GC.  Fortunately, the part is pretty cheap ($28 @ RockAuto) and you don't even have to lift the van to replace it.  Behind the rear axle-beam.
Driver's heated seat stopped working a few years ago, but I can live with that.
The Edmunds apprail estimate is about $4500, which seems about right to me.  All of the 2017 examples I see on Autotrader have higher asking prices, but those have less miles on them - and probably don't have a coyote-impact dent in the driver's door...
John Welsh
5/10/25 9:48 p.m.
Thermostat part arrived Fri.  I was contemplating a late Sat or early Sunday install.
But, Ive also had a tire light come on!  Significant low in LR incited more investigation and once dismounted I find a nail.  I repaired it with the classic push/pull style tire plug.
A quick drive after and the tire light is off.  But, oddly, the CEL light is off also.
Self healing thermostat?
3 4 5
hKv31gkkZmQ6rNYgIEwbnKn1TMs6DzfuCpRiHVKuWL7VArVEIzFH0enzOB960lno
