Dusterbd13-michael
Dusterbd13-michael MegaDork
3/3/23 6:59 a.m.
Any reason i cant/shouldn't use it to feed pressure from the knockoff walbro to the bulkhead fitting? Will be running 60psi-ish fir the ls swap. Would use efi style clamps at both ends. The foot of submersible rubber hose is $30 now....
Tyler H
Tyler H UberDork
3/3/23 9:31 a.m.
Send it.
APEowner
APEowner UltraDork
3/3/23 10:04 a.m.
Maybe.  Not all nylon tube is created equal.  Some of the marine stuff is only rated to 40psi.  If what you've got is actual automotive fuel line with a known rating then yes, it can be used.  However, it should only be used with the correct fittings and those are press fit and require a tool.
iansane
iansane Dork
3/3/23 10:05 a.m.
It came with the fuel pump? Use it. That's what it's for. Pretty much all manufacturers use that in their FP modules.
Dusterbd13-michael
3/3/23 10:44 a.m.
Cool. It was included in the box my new fuel pump came in, Along with the wiring, sock, a couple clamps, etc. I knew id neen them in oe pump modules, but couldn't remember the application.
Thanks yall!
06sVvrYPdNNa0LFtjqx9IBrFgnzmaqDgHE7NlxgN62AMphhxOtGvNXHLb6gY9ihA
