JohnRW1621
JohnRW1621 MegaDork
9/30/16 4:54 p.m.
During the autox the Nissan Quest did a combination of sounding louder, like intake noise and down on power.
It's throwing the codes P0011, & P0021.
What does the hive know?
mndsm
mndsm MegaDork
9/30/16 5:22 p.m.
P0011P0021
Sounds like vtc failure.
ssswitch
ssswitch Dork
9/30/16 5:25 p.m.
Maybe it oil starved. Sometimes Subarus will throw variable valve codes when they get low on oil in transitions.
Time for a mild overfill and ECU reset maybe?
Nessumsar
Nessumsar New Reader
9/30/16 6:20 p.m.
Those are the same codes my 04 Forester XT threw when it decided it wanted an oil change. I agree with ssswitch, top off a bit high and reset ECU.
Wall-e
Wall-e MegaDork
9/30/16 7:28 p.m.
It's toast. Dropping the body onto a Q45 should fix it.
Run_Away
Run_Away HalfDork
9/30/16 7:40 p.m.
Low oil pressure to the VTC system. Check your oil level. If it's good, mechanically check oil pressure. If that's good, then you may have a blown gasket in the timing cover where the oil supply to the VTC sprockets runs.
Esoteric Nixon
Esoteric Nixon UltraDork
10/1/16 8:17 a.m.
Now I know why it ran a 20 ¼. OK, check the air filter housing to see if it came loose. I know this sounds strange, but I've had it happened on a HHR that was being driven on some bad roads. It sounded louder, ran horribly, and shifted worse. Somehow the jostling had disconnected it from its mount on the intake.
Rwsh6gElQFuqI6Xly7G36xKDK9PHVaAFb1u2DKdpUJbozogGTVS9ummi0QdXlDKh
