wearymicrobe
wearymicrobe PowerDork
9/13/23 12:28 p.m.
I have a 2016 F150 with the 5.0 ~125K miles right now 4700 total running hours on the motor. Single cab, long bed,  2wd, locking rear gear with the short gear ratio. Compression check is in spec, no weird noises its my . Was a fleet truck and limited to 72mph its entire life and has spent a solid 1800 hours idling. I have addressed any and all wear on the rest of the truck.
Allegedly one of the truck forums is starting up a group by on the Roush supercharger at around 6500 for the sage 2 carb legal kit. I loved my Gen II lightning except that it could not really tow or haul with the short bed.
How terrible of a idea is supercharging a higher mileage 5.0. Being in California I cannot  do much beyond just bolt on the kit, nothing in the rotating assembly can be changed officially. Rings need to be stock things. I can do the install no problem but I have alwys done this on fresh motors and never had a issue.
9/13/23 12:38 p.m.
I don't have an expert opinion either way, I'm just here to enable.
Do it.
calteg
calteg SuperDork
9/13/23 12:48 p.m.
Sounds like you're setting yourself up for a traction issue. But you should still do it
Region_Rat
Region_Rat New Reader
9/13/23 12:50 p.m.
What's the worst that could happen?  Go for it!!
9/13/23 12:50 p.m.
Of course you should do it!
NOHOME MegaDork
9/13/23 12:56 p.m.
Are you even aware of the class of people to whom you are directing this question?
I trust you have already started the job?
Pete
RacetruckRon
RacetruckRon SuperDork
9/13/23 1:02 p.m.
What can be done to the ECU? Things will break if ignition timing and fuel delivery cannot be modified.
gumby
gumby Dork
9/13/23 1:10 p.m.
125k isn't high mileage anymore.
Do it. Full CARB legal kits include management and have multiple factors of safety. Do it.
bmw88rider
bmw88rider UberDork
9/13/23 1:34 p.m.
Agree with Gumby on both.
It's a CARB kit so it'll have good protective measures built into it.
570HP isn't super aggressive for that platform. Stock up on rear tires and send it.
thewheelman
thewheelman Reader
9/13/23 1:39 p.m.
If compression is good (no reason for it not to be), go for it. The Coyote is a stout motor. Swing over to www.mustang6g.com, guys there are adding superchargers on 100,000+ mile cars with no issues (as long as you don't get too power hungry).
buzzboy
buzzboy SuperDork
9/13/23 1:42 p.m.
Inb4 photo of new super charger at gas station
9/13/23 1:43 p.m.
This is the way.
9/13/23 1:56 p.m.
do it.  do it for the children.  do it for us.  do it because you have worked hard and can afford to do it.
wearymicrobe
9/13/23 2:12 p.m.
Actually would order the upgraded 670hp kit, it has the carb sticker already and comes with the tune and injectors, everything in one box.
You guys are a bunch of enablers. I love it.
Tractions is definitely going to be a problem, I was running DOT slicks on my lightning and that made only 500ish to the wheel and had the steel bed. The truck already breaks traction now at will down low.
Boost_Crazy
Boost_Crazy Dork
9/13/23 2:39 p.m.
In reply to wearymicrobe :
Didn't Ford sell these through dealers, both installed on new trucks and through their parts departments? Everything I've heard has been that they have been factory reliable. 125k is just broken in. I remember when dealers were advertising 600+ HP F150's for just under $40k, the best HP per dollar deal on the market.
clutchsmoke
clutchsmoke UltraDork
9/13/23 3:28 p.m.
Definitely do it. The only con I can think of is increased fuel consumption.
RaabTheSaab
RaabTheSaab Reader
9/13/23 3:37 p.m.
What a weird title for a build thread
9/13/23 3:54 p.m.
Install higher gears. Take some of the punch out of it. Conversely, you'll create a highway cruise missile.
Piguin
Piguin New Reader
9/13/23 5:12 p.m.
I think I need to be the voice of reason here.
Oh, who am I kidding? DO IT
LukeGT
LukeGT New Reader
9/13/23 5:59 p.m.
Gen 2s are generally speaking the most robust and reliable of the "normal" Coyote engines. As long as it's well maintained you shouldn't have any issues.
APEowner
APEowner UltraDork
9/13/23 6:29 p.m.
Not that I'm known for having the best judgment in such things but I'd do it.
9/13/23 6:59 p.m.
Are you going to be swapping a high mileage engine in?
Shavarsh
Shavarsh HalfDork
9/13/23 7:08 p.m.
Let me know if you need a hand.
calteg
calteg SuperDork
9/13/23 7:10 p.m.
I bet 335's will fit with enough sawzall'ing
Will
Will UberDork
9/13/23 7:28 p.m.
The smog station isn't going to tear down your motor like a post-race NASCAR inspection. If it looks stock aside from the blower and you have a sticker for that, you'll be fine.
zLryz9WVXEX0egiULY7pGWQgwbVOHRi1TtdRI9nJzeXcQy6GMfwtXj6X2bLX0XWm
