NoMini
NoMini PowerDork
8/1/18 12:09 p.m.
The hole in a new tie rod end is too far out, for the split pin to engage the castle nut.
Would a dab of hot glue be ok, or should I try to drill a new hole?
stafford1500
stafford1500 HalfDork
8/1/18 12:11 p.m.
Blue loctite or drill a new hole
OR
Add a washer or two under the nut to get the serations at the right place
Dusterbd13
Dusterbd13 MegaDork
8/1/18 12:15 p.m.
OR
Washers have worked every time in this application to fix it. For well over 100k under me.
02Pilot
02Pilot Dork
8/1/18 12:15 p.m.
Yeah, I'd think a thick steel washer under the nut would solve the problem and be a good idea generally to spread the clamping force across the mating surface.
AngryCorvair
AngryCorvair MegaDork
8/1/18 12:16 p.m.
washer
FIYAPOWA
FIYAPOWA Reader
8/1/18 12:27 p.m.
Washer.
Just wanting to see how many "washer" comments you get lol.
SaltyDog
SaltyDog HalfDork
8/1/18 1:19 p.m.
washer (6)
NoMini
NoMini PowerDork
8/1/18 1:20 p.m.
Okey dokey. Washer it is. Duh. Sometimes the simplest solutions evade me.
thatsnowinnebago
thatsnowinnebago SuperDork
8/1/18 1:41 p.m.
Have you thought about trying a washer yet?
Toyman01
Toyman01 MegaDork
8/1/18 1:43 p.m.
Not sure, but maybe a washer would work...
tuna55
tuna55 MegaDork
8/1/18 1:56 p.m.
The first time I heard my Dad talking about washers (I was maybe six) I was trying to figure out how it washed anything.
I think my exact words were "TunaDad, I can't see how this can wash anything. Though now that I see one, I can easily see how it would be useful if your balljoint nut ever placed the cotter pin too far above the castlenut to engage properly."
dj06482
dj06482 SuperDork
8/1/18 1:58 p.m.
I haven't read the previous posts, but think washers would solve your problem...
NoMini
NoMini PowerDork
8/1/18 2:05 p.m.
In reply to dj06482 :
Liar.
airwerks
airwerks Reader
8/1/18 2:09 p.m.
Jam nut.
Sorry, I just have to be different.
TED_fiestaHP
TED_fiestaHP Reader
8/1/18 2:10 p.m.
  Self locking nut, forget the cotter pin....
T.J.
T.J. MegaDork
8/1/18 2:15 p.m.
It seems to me that an easy solution might be to place some sort of metal piece behind the castle nut so that it lines up with the drilled hole. The piece should have a round through hole in the center so it can slip over the threaded portion and be captured once the whole assembly is made up. So, what your going to need is a round holed metal shimmy spacerery thing.
Professor_Brap
Professor_Brap Reader
8/1/18 2:17 p.m.
Id go for a washer
NOT A TA
NOT A TA Dork
8/1/18 3:03 p.m.
New nut doesn't match the witness mark left by the old nut.  Looks like old nut was a larger size.  Are you sure the new part is correct and has the same size taper as the old one?
8/1/18 3:07 p.m.
In reply to NOT A TA :
Wouldn't a washer be an easier solution?
EastCoastMojo
EastCoastMojo Mod Squad
8/1/18 3:08 p.m.
Cotter pin shaped like a top hat. laugh LOL
Toyman01
Toyman01 MegaDork
8/1/18 3:29 p.m.
Or!!! Epiphany time here!! The above mentioned marks may have been made by that missing washer!!!
Matthew Kennedy
Matthew Kennedy Reader
8/1/18 3:37 p.m.
What if you could manufacture a plate with a hole for the stud to fit thru, placed under the nut, with adequate thickness to line the castle nut up with the cross hole?
Robbie
Robbie PowerDork
8/1/18 3:42 p.m.
can we call this washer a dungeon washer or perhaps a moat washer because it goes under the castle nut?
fasted58
fasted58 MegaDork
8/1/18 3:44 p.m.
TLDR
but I'd say washer
Dusterbd13
Dusterbd13 MegaDork
8/1/18 4:18 p.m.
A lot of the cheap chassis parts ive boght (and expensive) lately have smaller than original fasteners. Buy up to three wrench sizes. Don't know why that is but the tapers and everything else match up perfectly
TVxagwg5zqWeiVUJUCpJqVgdsFZ6AeZvMuQ12FiY6VqA9JInPRNtpLtoptPSNU6w
