MrLittle
MrLittle New Reader
1/6/16 8:44 p.m.
So I'm looking at winter tires to use as rallycross tires for 944 and I've come across this deal - Continental Tires
The tires on the car right now are 215/60/r15 and those are 195/65/r15 (linked above). They came up as an alternate on tire rack and wasn't certain if it means alternate as in it could have came with a different wheel or if it meant they would fit on the wheels I have currently.
Btw, I feel really dumb asking this question but can't seem to wrap my head around it.
Thank you for your kind wisdom in advance!
captdownshift
captdownshift UltraDork
1/6/16 8:49 p.m.
Run them on the wheels that you have, bonus is the narrow footprint will do better in the snow
Kenny_McCormic
Kenny_McCormic UltimaDork
1/6/16 8:56 p.m.
Does the wheel you run fit within the recommended wheel width for the 195/65R15? Can you live with the slightly shorter tire reducing ground clearance?
Have you heard of anybody else running these in rallyx? I was under the impression you wanted a studdable winter tire for that, as they are generally a harder compound that holds up better on the dirt/gravel. Not a problem if you're running them in winter, but a valid concern, not much of a deal if you burn them up in a couple events.
MrLittle
MrLittle New Reader
1/6/16 9:04 p.m.
In reply to Kenny_McCormic:
Good points sir. I really can't afford to lose any ground clearance.
It doesn't matter anymore actually, the site says less than 10 remaining and when you go to checkout they say unavailable. I think I'll end up going with some altimax artics (studdable) and they are only $20.00 more a tire.
Also, in talking with my brother he posed the point of finding a symmetrical tire (sadly the artics are not) vs asymmetrical for rotation purposes.
For the rallyx folks, what sort of tire do you see people or you yourself run?
captdownshift
1/6/16 9:09 p.m.
For rallycross I'd get the highest speed rated (for sidewall stiffness; helps prevent debeading and improve turn in response) snow tire available within your budget. I'm a believer that the sidewall stiffness of the snow tire matters more than the tread pattern
Robbie
Robbie SuperDork
1/6/16 9:13 p.m.
captdownshift wrote: For rallycross I'd get the highest speed rated (for sidewall stiffness; helps prevent debeading and improve turn in response) snow tire available within your budget. I'm a believer that the sidewall stiffness of the snow tire matters more than the tread pattern
Interesting. Not sure I would have thought of that on my own but it makes good sense. Thanks! (And I didn't even start this thread).
Knurled
Knurled MegaDork
1/6/16 9:13 p.m.
Yeah, but you'd have to try very hard to debead with a rear-driver, and snow tires' advantage over rally tires is their lower rolling resistance, which is a huge factor in an underpowered car like a 944.
DzBhQ0ECJpvBgBbF2Akcy7qyGTy7vHdNnwpbllXZfbYbsFzG5XhnWwh6V1fs0rgV
