MoCounselor
MoCounselor New Reader
3/2/17 6:38 p.m.
As most of you know, it's becoming harder and harder to find 15" tires that are anything other than all-season, low noise, low grip tires. I have a set of 15" wheels on my project Volvo 242 that I want to keep for awhile, but they need tires. What would you all recommend for a decent, performance oriented tire in a 205/60-15 size? (I know I can get Azenis in a 205/50, but stock size is a 195/70-14 and the tires on my wheels right now are a 195/60-15, so dropping down to a 205/50 would be a HUGE diameter change.)
Thanks in advance, fellow car nerds!
-Ben
Ransom
Ransom PowerDork
3/2/17 6:48 p.m.
I was about to argue with you about 15" availability, but the 205/60-15 does seem to be a different story...
At the far other end of the spectrum from all-seasons, Tire Rack's got Yokohama Advan A048s in that size :)
RevRico
RevRico SuperDork
3/2/17 6:52 p.m.
Yea, 205/60 is a strange size, I wound up losing the extra half inch in height for much wider availability going to 205/50 instead.
Being a 1" difference from 195/60 to 205/50 .. I don't know if I'd call it huge, I guess that depends on how low you sit already.
irish44j
irish44j UltimaDork
3/2/17 9:12 p.m.
I have star specs on the e30's 15s for street driving. And Alimax Arctics for the winter.
Vracer111
Vracer111 Reader
3/2/17 9:44 p.m.
Well other than the Yokohama ADVAN A048 in that size on tire Rack, it's all junk tires if you care about performance...
If you went with 17" wheels and 205/45-17 tires they would be righ around the correct diameter, weigh the same, and you would have tons of high performance tires to choose from... just a thought.
There's also 225/50-15 tires...~23.7" diameter. Mainly specced in track tires though...
wvumtnbkr
wvumtnbkr SuperDork
3/3/17 5:47 a.m.
There is also the maxxis and rs4 available in 245/45/15.
iceracer
iceracer UltimaDork
3/3/17 10:37 a.m.
Revs per mile. find something close.
A 1" smaller diameter tire will lower the car 1/2".
JBasham
JBasham Reader
3/3/17 3:33 p.m.
I'm in a similar sitch now. E36 with 195/60/15 stock wheels. It's for HPDE so I don't seem to have any choice other than make the 50 aspect tires work.
Toebra
Toebra Reader
3/3/17 4:16 p.m.
195/55/15 opens up some choices for you
mEyhXb5Eu96eUM9KBYwY95KrQNbslGGVOZF69P3HQdwd4Kvl8TBvDjLhz1i4VQly
