poopshovel
poopshovel MegaDork
9/16/14 8:42 a.m.
I rode in a buddy's new Camaro a few weeks ago. Sounded NASTY (in a good way.) Asked him what he'd done to the exhaust, and turns out, he'd just pulled the mufflers.
I'd thought about it on the V but worried I'd be "that guy" in the neighborhood/that it might be annoying on the hwy, but at low RPM, the Camaro was surprisingly stock sounding.
Thoughts?
Gearheadotaku
Gearheadotaku PowerDork
9/16/14 8:50 a.m.
Take them off and try it. You can always put them back on.
Cotton
Cotton UltraDork
9/16/14 8:52 a.m.
take em off.
Giant Purple Snorklewacker
9/16/14 8:57 a.m.
I think you might be "that guy" but... try it. If it's too much go buy some Flowmaster 40s to knock it down at low RPMs and still howl when you get on it.
Joe Gearin
9/16/14 9:06 a.m.
Who's fooling who Poop------ you are already "that guy" Go ahead--- turn it up to eleven!
fasted58
fasted58 PowerDork
9/16/14 9:08 a.m.
Went muffler delete w/ axle back Pype Bombs on the '05 S197, retained the cats and stock mid pipes tho. Nothin' crazy but makes all the right noises from idle on up, the way it oughta be, love it.
I'd give delete a shot. Like said, you could always reinstall.
Cotton
Cotton UltraDork
9/16/14 9:11 a.m.
if the "no mufflers" end up being too loud you might look at a Corsa system. The loud version of the corsa system sounds awesome on my buddies c5.
9/16/14 9:13 a.m.
Electric cutouts. You can either be Miss Jackson or Janet, depending on your mood.
9/16/14 9:14 a.m.
The old 9C1 had mufflers and resonators. When the mufflers rotted off, I just used the straight through resonators. Straight pipes, really. Quiet until you romped on it.
Bobzilla
Bobzilla PowerDork
9/16/14 9:16 a.m.
Friend of ours runs his '06 -V without mufflers. not loud. Sounds fantastic.
9/16/14 9:20 a.m.
+1 for remove the muffler section and see how it sounds. Replacing the mufflers with straight pipes will sound similar.
Will
Will SuperDork
9/16/14 10:02 a.m.
Cotton wrote: if the "no mufflers" end up being too loud you might look at a Corsa system. The loud version of the corsa system sounds awesome on my buddies c5.
I installed the Corsa on my CTS-V, and while it sounded amazing, it actually dropped a couple hp on the dyno. It was also 7 pounds heavier than the stock exhaust. I'd probably still do it again, though. It sounded that good.
On the CTS-V, the entire catback is a single piece, so you'll have to cut the mufflers off--you can't just unbolt them. They should be easy enough to seal back up with band clamps, but it's something to be aware of.
9/16/14 10:08 a.m.
Will wrote: On the CTS-V, the entire catback is a single piece, so you'll have to cut the mufflers off--you can't just unbolt them. They should be easy enough to seal back up with band clamps, but it's something to be aware of.
This makes it easy to go to/from cleanly: http://www.ebay.com/itm/300860163498
poopshovel
poopshovel MegaDork
9/16/14 10:26 a.m.
Sweet. Thanks dudes. Thought about cutouts, but $$$.
clutchsmoke
clutchsmoke Dork
9/16/14 10:30 a.m.
Chop chop! Sick some tubes on there to get it exiting past the bumper and call it a day.
OneJay
OneJay New Reader
9/16/14 10:39 a.m.
A friend of mine deleted the mufflers on his V. It was on the loud side, but sounded great!
JacktheRiffer
JacktheRiffer Reader
9/16/14 10:46 a.m.
Do it! Cant be that bad for your neighbors
poopshovel
poopshovel MegaDork
9/16/14 11:00 a.m.
JacktheRiffer wrote: Do it! Cant be that bad for your neighbors
And berkeley em anyway. I've had to listen to barky dogs and Harleys for 13 years now
MG Bryan
MG Bryan SuperDork
9/16/14 11:08 a.m.
Poop starts a thread worried about being "that guy." 18 posts later, "berkeley the neighbors." I love it.
wspohn
wspohn HalfDork
9/16/14 11:13 a.m.
Absolutely no way to tell (except someone else that has the same set up, if they speak up) without trying it. Costs a bit to try but at least you'll know. If you do it and it is too loud, you can look at inserting a low restriction small muffler or resonator to tame it a bit.
I removed an intermediate muffler on my old Italian beast as it was far to polite, and now it sounds glorious!
Sky_Render
Sky_Render Dork
9/16/14 1:26 p.m.
Test it out on the highway before you completely decide. The 2,000-RPM drone of the American V8 without chambered mufflers can get quite annoying.
mazdeuce
mazdeuce UberDork
9/16/14 1:28 p.m.
Sky_Render wrote: Test it out on the highway before you completely decide. The 2,000-RPM drone of the American V8 without chambered mufflers can get quite annoying.
This is what has me leaning toward cutouts on my wagon. As much as I want it to sound like the glorious beast that it is, I've grown to love the quiet highway cruising.
Cotton
Cotton UltraDork
9/16/14 2:10 p.m.
is there a cutout that doesn't leak now? Last I check even the swanky electrical ones would leak after awhile. I like the thought of cutouts, but can't stand exhaust leaks.
mazdeuce
mazdeuce UberDork
9/16/14 2:44 p.m.
In reply to Cotton:
I expect they would require periodic maintence.
Kenny_McCormic
Kenny_McCormic PowerDork
9/16/14 3:06 p.m.
V8 with straight pipes isn't all that loud, so long as you drive it gently.
7ucakAIiLRo97DDH6xiMcSzOG9DUfreHn01tNvzai2OOuIyTzIfMzHrh18xjTe2R
