2/4/13 3:43 p.m.
Don't try to make it Locost, make it expensive and worth it. Build replicas/recreations, not kits. Locost manufacturers all have one thing in common: they're out of business.
As for the "GTO Miata", are you thinking of the old Italia? Based on a NART Spider. The angle of the photograph makes a big difference, the rear fenders are about 1" wider due to the fiberglass overlay. I put a set of 1" spacers on one of those and it helped the car quite a bit visually. I've never seen a GTO replica based on a Miata, only 240Z ones.
Swank Force One
Swank Force One MegaDork
2/4/13 3:48 p.m.
There's one floating around out there that looks DAMN GOOD (same kit, but whomever did the conversion did a beautiful job), but here's what i can find quickly for the moment.
DeadSkunk
DeadSkunk Dork
2/4/13 4:32 p.m.
The rear 3/4 view doesn't quite work for me. A little too bulbous looking.
Type Q
Type Q Dork
2/4/13 6:18 p.m.
Ian F wrote:
JFX001 wrote: The company is called Road Star Garage. They also have a replica based on a 240Z.
Roadster Garage in Japan? http://translate.google.com/translate?hl=en&sl=ja&u=http://roadstergarage.jp/&prev=/search%3Fq%3Droad%2Bstar%2Bgarage%26hl%3Den%26tbo%3Dd%26biw%3D1117%26bih%3D685&sa=X&ei=5moKUY2tH4yo8QT20ICQCQ&sqi=2&ved=0CDMQ7gEwAA
Thank you. I saw both versions of the Roadster Garage replica at the Tokyo Motor Salon about 4 years ago and met the owner of the company. The coupe in particular was beautilful. The whole project was clearly a labor for those involved. I don't they were making any real money.
otIvqjb9QNnhjX9jeXmIVCc7sxDTZbxic8RE8AlBUsLxsT4n1cBMdQNR1zYZ2VkQ
