I may have come across a cheap Tracer LTS that would make a fun car to thrash around in. I do have a quick question for the ford/mazda people here though, are there any differences in the suspension between the hatch back escort gt and tracer lts/escort lxe? I know they have the all important mazda BP power plant but I am not sure what the other differences are. Is it basically a protege lx?
P71
SuperDork
7/19/10 10:58 p.m.
Is that the mythical V6/AWD beast?
I didn't think the LX came with the BP, though I could be wrong.
The one I drove was geared really short. Seemed like almost 4000rpm at interstate speed. That's all I remember.
Everything should interchange.
As far as I know there was never a v6 awd escort/t-racer, at least not in the states. Maybe your thinking if the tempo, Maybe?
Joey
The Protege LX does come with a BP. And yes the gearing is ridiculous.
Joey
a girl I liked back in highschool had one of those
Just to reiterate, everything should be interchangeable. The only suspension difference I can think of that there might be is the rear sway bar. EGTs had 21mm, wagons had big ones too.
FYI, The BP in there is just as susceptible to the crank snout issue as the BPs in Miatas. This led to the demise of my beater EGT.
I can vouch for that. When I had my Tracer I remember a lot of guys raiding junkyards for the wagon's stiffer rear bar, which was the same as the GT's. It's possible that the LTS also got it, though I'm not positive.
Just make sure it's not an automatic. Those transmissions are made of glass. I went through 2 in my 95 Tracer, and it was just the basic 88hp version. If it's a stick, you'll be fine. The LTS is a good stealthy performer - the red, rather than chrome, stripe is the only hint that it's anything special.
Only the early early cars are. 91 and 92 only i believe. 93+ are fine.
About 3400rpms at 70mph. It's tight, but it's not insane or anything.
You want truly ridiculous gearing? Drive an MX3 GS.
OP, i am jealous. I want one for ST/FSP duty just because it would be hilarious.
No difference in main suspension.
Both have the rear discs.
I have an LTS suspension under my 91 Pony Escort, except I used a 3rd gen front subframe as it was attached to the larger (25mm?) 3rd gen sway bar.
http://www.feoa.net/modules.php?name=Forums&file=viewtopic&t=55277&highlight=4wd
4wd stuff can be found here!
Bruce
There were V6 versions of that chassis (MX-3) and AWD versions (some very rare Protege variants) but none that paired the two together.
The one I found is a 91, so possible crank issues. Waiting to find out if it has the correct transmission.
But you can't drive 70 where I live without fearing for your life. So I'm usually buzzing along at about 4 grand to run 80.
It's not horribly common or anything. That said, i will have a spare BP in the next couple months that i'd let go for cheap. It's a 93. It smokes some, but i'm pretty sure that's because the head that's on there has no valve seals anymore. Makes great power, so i would imagine the bottom end is fine. I have a spare head that came off of CGHstang's car as well that should be in better shape.
Hmm. Seems as though we're destined to have a long-haul swap meet in the near future. Would be a good excuse to see some friends in/around Evansville....
P71
SuperDork
7/20/10 10:10 a.m.
I think I'm thinking of the Topaz LTS / Tempo ???
Later model ZX2's and Escort sedans had better gearing and on some the 5th gear is interchangable without removing the transaxle.
Cuts the rpm to 3K at 70.
Do it! Bring me lots of cool stuff for the KLZE 'Scort and the MX6.
psteav
Reader
7/20/10 1:03 p.m.
yeah, that was nothing special and all ford. 3.0 Vulcan with a five speed...I found one once, for cheap, in nice shape. The general consensus was "it's not even really worth it for a beater".
I remember this was possible with the 2ng gen ford probe /mx6 too. Another variant of the same trans I suppose.
No reply on the car yet.
Yeah, they're all Mazda G-series trash transmissions.
