outasite
outasite New Reader
5/14/15 2:44 p.m.
Just sold my 92 NA and bought a 99 NB. I used Redline fluids in the transmission and differential (non Torsen) with no problems. The NB did not want to coast well in gear so I sorted through the records w/car and found the fluid in transmission and differential (Torsen) had been replaced w/80W140 at a dealership. I checked the manual and found the factory recommends 75-90 in the transmission and GL5 in the differential. Went to Miata.net and read the oil and fluids forum. Found owners talking about Ford Fluid XT-M5-QS full synthetic MTL in transmission improved shifting in the NA Miatas. Nothing about NBs. What do you KNOW about using the Ford fluid in the NBs? Other suggested fluids? Thanks
5/14/15 2:57 p.m.
The NA and NB transmissions are so similar as to make no difference. Use the same fluids.
I'm still using Redline MTL because it just plain works.
amg_rx7
amg_rx7 SuperDork
5/14/15 2:58 p.m.
Same fluid choices apply to the NB
Desmond
Desmond Reader
5/14/15 3:14 p.m.
The Ford/Motorcraft XT-M5-QS stuff is the best fluid I've used for the Miata. Took a lot of the roughness out of my transmission, and even remedied my crunchy 2nd gear shift. However, the Ford stuff can be spendy. If not that, I would go Redline MTL/MT90.
Then I do Redline 75W90NS (non-slip) in the diff. Works awesome for daily/weekend track use.
Swank Force One
Swank Force One MegaDork
5/14/15 3:38 p.m.
Personal preference to a point.
I use Amsoil MTG in trans, SVG in diff. Redline for some reason made my MSM extremely notchy and rough feeling, so i swapped it out. Might have been fine in any of the 4 Miatas that followed, but staying consistent is easier for me to remember, and i already put MTG in everything else.
Dashpot
Dashpot Reader
5/14/15 5:46 p.m.
Desmond wrote: The Ford/Motorcraft XT-M5-QS stuff is the best fluid I've used for the Miata. Took a lot of the roughness out of my transmission, and even remedied my crunchy 2nd gear shift. However, the Ford stuff can be spendy. If not that, I would go Redline MTL/MT90. Then I do Redline 75W90NS (non-slip) in the diff. Works awesome for daily/weekend track use.
Agreed, used both in both 5 & 6 speed gearboxes. Redline's fine for the 5 speed, not as great in the 6 speed. I saw an improvement with the Ford stuff in the 6 speed.
Woody
Woody MegaDork
5/14/15 8:53 p.m.
I used MTL in my 2000. I did the shifter boots and turret oil too and it shifts like new.
outasite
outasite New Reader
6/6/15 5:06 p.m.
Thanks, I used MTL in the transmission and synthetic in the differential and put some miles on it. Now it coasts and shifts great.
JoeTR6
JoeTR6 Reader
6/6/15 9:40 p.m.
I found the same thing as Swank with my Mazdaspeed. MTL worked great in my NA, but for some reason made the Mazdaspeed notchy. It shifts much better with Motorcraft XT-M5-QS.
outasite
outasite Reader
10/5/15 10:18 p.m.
In reply to Keith Tanner:
Thanks Keith, used MTL as suggested and did a couple of road trips this summer. Transmission is shifting like new.
3vxWaeMuQzO9fqnf0VCkRNujsrtbH0nVaa1dqmnxCrY8nZ0iCZSyVE15r6nXVMfE
