ProDarwin
ProDarwin PowerDork
2/12/18 11:56 a.m.
Does anyone know the true O.D. and I.D. of mild steel 2.5" exhaust pipe?  I don't have the pipe in front of me.  Specifically this  https://www.speedwaymotors.com/Combo-Exhaust-Pipe-Mandrel-Bend-Header-Tubing-Mild-Steel-2-1-2-Inch,67444.html
Site says 2.5" x 0.060" wall.  Is it truly 2.500" O.D. and 2.380" ID?
stafford1500
stafford1500 HalfDork
2/12/18 11:59 a.m.
Generally, tube as you described above is spec'd based on the outside diameter. So yes it should be 2.50+/-" on the outside with a 2.38+/-" inside diameter.
Pipe (generally thicker wall) is based off a nominal size that is not usually equal to the actual measurements.
WHfkZ81gRsYcuMnJtdYmrGb9423d3DhL7BXbSaY7ekG2UTKNETfe1D50YiwiGgPw
