Woody
Woody MegaDork
4/28/14 9:58 a.m.
You heard me.
NONACK
NONACK Reader
4/28/14 10:12 a.m.
You can figure out fore-aft CG from the static weight distribution: 50/50 means it'll be dead center between the wheels, 66.7/33.3 would be 1/3 of the way back from the front wheels to the rears, etc.
I don't know of a resource for vertical CG.
Woody
Woody MegaDork
4/28/14 10:25 a.m.
I can't imagine that shops do that for every vehicle that rolls in, but I'm also I'm sure that most just wing. That said, there must be some sort of industry guide.
I'm trying to figure out where to position a lift in my garage.
NONACK
NONACK Reader
4/28/14 10:33 a.m.
In reply to Woody:
That's a nice problem to have... I would think the equation would be driven by the longest vehicle with the worst weight distribution than you anticipate working on- a truck, maybe?
To really throw a wrench in this, what about the massive CG shift you get when you pull the drivetrain out of something? Or the engine out of the front of something with a rear transaxle?
bludroptop
bludroptop SuperDork
4/28/14 10:34 a.m.
NONACK wrote: To really throw a wrench in this, what about the massive CG shift you get when you pull the drivetrain out of something? Or the engine out of the front of something with a rear transaxle?
Yeah, um... be careful with that.
fidelity101
fidelity101 Dork
4/28/14 10:52 a.m.
Woody wrote: You heard me.
I read you.
Woody
Woody MegaDork
4/28/14 12:01 p.m.
NONACK wrote: In reply to Woody: That's a nice problem to have... I would think the equation would be driven by the longest vehicle with the worst weight distribution than you anticipate working on- a truck, maybe?
oldopelguy
oldopelguy SuperDork
4/28/14 12:07 p.m.
Swing the arms wide and find the center of their reach? That should roughly correspond to where the lift manufacturer thought that center of the car should be and if you center that point in your space you should be close.
NONACK
NONACK Reader
4/28/14 12:12 p.m.
In reply to Woody:
Right. So figure out the CG to rear bumper distance on that beast, and put the center of the lift at least that far away from whatever it is you're concerned about clearing, plus a little room to move around?
bravenrace
bravenrace UltimaDork
4/28/14 12:39 p.m.
In reply to Woody:
You're over thinking it. We always just took a guess, raised it up so the tires were just off the ground, pushed on the front and the rear, and decided if any adjustment needed to be made. Common sense prevails.
Woody
Woody MegaDork
4/28/14 12:44 p.m.
bravenrace wrote: Common sense prevails.
That's what I was afraid of...
bravenrace
4/28/14 12:57 p.m.
In reply to Woody:
Why? Are you having a hard time finding it?
Sky_Render
Sky_Render Dork
4/28/14 1:06 p.m.
The shop that lets me graciously "rent" a 2-post lift occasionally has a paperback book that lists just about every vehicle ever and shows their lift points.
Woody
Woody MegaDork
4/28/14 1:13 p.m.
That's the book that I'm looking for.
edizzle89
edizzle89 Reader
4/28/14 1:16 p.m.
bravenrace wrote: In reply to Woody: You're over thinking it. We always just took a guess, raised it up so the tires were just off the ground, pushed on the front and the rear, and decided if any adjustment needed to be made. Common sense prevails.
this is always what we did down at school, get the tires about 3-6 inches off the ground and rock the car to see if adjustments need to be made, also one of these at the front and rear of the vehicle takes the worry out of it:
ryanty22
ryanty22 Reader
4/28/14 1:29 p.m.
great tools to have around and pretty cheap too
bravenrace
4/28/14 1:30 p.m.
In reply to Woody:
You wouldn't have this issue at all if you bought a 4 post lift like I told you...
4/28/14 1:32 p.m.
If you ever find yourself asking, "Is there a resource that shows the X of all vehicles?" where X is not stock tire size, factory alignment spec, or lug torque spec, the answer is no.
Sky_Render
Sky_Render Dork
4/28/14 2:26 p.m.
GameboyRMH wrote: If you ever find yourself asking, "Is there a resource that shows the X of all vehicles?" where X is not stock tire size, factory alignment spec, or lug torque spec, the answer is no.
This is completely incorrect. As I said, there is a book that lists lift points. I do not, however, know who publishes it.
johndej
johndej New Reader
4/28/14 2:39 p.m.
https://www.autolift.org/store.php#ALCTV-2011 $10 here
codrus
codrus HalfDork
4/28/14 4:03 p.m.
From what I hear, entirely too few people did this properly where Elises were concerned.
1988RedT2
1988RedT2 PowerDork
4/28/14 4:06 p.m.
I don't see the big deal. I mean, what's the worst that could happen?
Okay, don't lift any Toyota trucks and you should be good.
BoxheadTim
BoxheadTim PowerDork
4/28/14 4:18 p.m.
Elises have very specific lift points on their chassis due to the way the chassis has been designed. Mine even came from the factor with "dot" stickers that show you where to put the arms.
Duke UltimaDork
4/28/14 4:24 p.m.
1988RedT2 wrote: I don't see the big deal. I mean, what's the worst that could happen? Okay, don't lift any Toyota trucks and you should be good.
The absolute BEST part of that picture is the sizeable pile of frame rust on the ground below the failure point.
scottdownsouth
scottdownsouth New Reader
4/28/14 4:25 p.m.
I hated to lift my old boss mans 4x4 Chevy dully ..he had the back full of everything a rigger could ever need.lift with caution !
tsjdD5BQqsOx2yQHzSt9gY6R5oDiqDPIXTfCFAZUQet4cEbceb72halgBv82GeKE
