tuna55
tuna55 UltimaDork
11/4/14 9:37 a.m.
Has anyone ever done this? I am imagining two different sized turbochargers plumbed to a plenum of exhaust from the manifold(s), and both feeding into the intake. I am unsure if the downstream air from one turbo will try and feed the downstream end of the other, but I imagine this has to happen a small amount with twin setups as well as nothing is every truly identical.
Ranger50
Ranger50 PowerDork
11/4/14 9:40 a.m.
Vaguely sounds like the turbo setup on the 6.7 Powerstroke....
cdowd
cdowd HalfDork
11/4/14 10:45 a.m.
I think the Saab 9-5 with the 6 cylinder had an assymetric twin turbo system. these were used from 99-03.
Swank Force One
Swank Force One MegaDork
11/4/14 10:52 a.m.
cdowd wrote: I think the Saab 9-5 with the 6 cylinder had an assymetric twin turbo system. these were used from 99-03.
I believe those just had one turbo... driven off of one bank.
Kenny_McCormic
Kenny_McCormic PowerDork
11/4/14 11:00 a.m.
Put a check valve or some sort of pressure differential operated butterfly valve on the bigger one, problem solved.
Edit: Better idea, check valve on the inlets of both.
Ojala
Ojala HalfDork
11/4/14 11:01 a.m.
In reply to Swank Force One:
Yup, the dreaded 3.0t, which was definitely not the best engine effort to come out of GM/Saab.
kb58
kb58 Dork
11/4/14 11:05 a.m.
Presumably the smaller one will spin up first and try to back-drive the larger one, then as the engine speeds up, the larger unit may try to back-drive the smaller. Seems like it won't work without some management.
Fueled by Caffeine
Fueled by Caffeine MegaDork
11/4/14 11:22 a.m.
Exhaust throttle might work, but hard to make work.....
Fueled by Caffeine
11/4/14 11:40 a.m.
kb58 wrote: Presumably the smaller one will spin up first and try to back-drive the larger one, then as the engine speeds up, the larger unit may try to back-drive the smaller. Seems like it won't work without some management.
I've seen experiments with valve to switch exhaust gas flow, but nothing was able to be reliable enough to come to market.
Kenny_McCormic
11/4/14 11:42 a.m.
In reply to Fueled by Caffeine:
I think the primary concern is a boost leak out the intake of one turbo or the other.
Driven5
Driven5 HalfDork
11/4/14 12:09 p.m.
Isn't this the same basic idea as "sequential" turbocharging, as used on the 2JZ-GTE in the Mk. IV Supra Turbo...Or am I misinterpreting your description?
Rusted_Busted_Spit
Rusted_Busted_Spit UltraDork
11/4/14 12:11 p.m.
Driven5 wrote: This is called "sequential" turbocharging, and is what was used on the 2JZ-GTE in the Mk. IV Supra Turbo.
I think the FD RX 7 was the same way.
tuna55
tuna55 UltimaDork
11/4/14 12:29 p.m.
They had one turbo feeding another feeding the engine. I mean the engine feeding two turbos which feed the engine, but the two of them are not the same size.
Rupert
Rupert HalfDork
11/4/14 12:42 p.m.
Detroit Diesel does a somewhat similar trick with some diesel engines. First off, being 2-strokes they need a pressurized intake even at idle. So they supercharge the intake. Then they have a turbo which takes the intake fan up to a much higher rpm under load.
nderwater
nderwater PowerDork
11/4/14 12:44 p.m.
Vid starts with cylinder counts and then shows how turbocharging plays in:
http://www.youtube.com/watch?v=eusyBOvrqrc
Fueled by Caffeine
11/4/14 12:59 p.m.
Kenny_McCormic wrote: In reply to Fueled by Caffeine: I think the primary concern is a boost leak out the intake of one turbo or the other.
Naa.. Primary concern was a moving valve in the exhaust stream.
Dig around about this motor, that was but never was, and you can find pictures of the valve. http://www.allpar.com/news/index.php/2010/12/ram-1500-v8-diesel-2013-civilian-launch
rLUujFA4DiE6qJPL035egop5wwEkpM5Yl0lXCkYVVPP8jzE5Rln8JAvV2HGELSOW
