Twin_Cam
Twin_Cam UltraDork
5/9/12 9:54 p.m.
I recently added an OBX exhaust to my daily driver. The original exhaust was swiss cheese'd with rust, and this replacement was cheap, mandrel-bent, and made of 304 stainless. Sold. Only one problem (other than poor fitment, which I am done trying to fix): the muffler is shiny, and can be seen from the back of the car, and it has a 3" outlet with a stylized tip on it.
This is attracting very unwanted attention from the brotato/flat-biller/"I drive a E36 M3ty Honda with clear taillights and I want to race everything on the road" crowd. So I'm going to hack the ricer tip off and just weld on a standard piece of stainless. The polished part though...
What's the easiest way to un-polish it? Burnishing pad? Wire wheel? Acid wash? Kitten tears?
jere
jere New Reader
5/9/12 9:57 p.m.
Sandpaper just don't go to coarse, or if you have a sandblaster maybe that.
fast_eddie_72
fast_eddie_72 SuperDork
5/9/12 9:59 p.m.
Yeah, I was going to say blast it with glass bead. Never done it on stainless, but it makes a nice kind of satin finish on aluminum wheels.
Keith
Keith MegaDork
5/10/12 12:21 a.m.
BBQ paint.
Appleseed PowerDork
5/10/12 12:53 a.m.
Scotch brite pads?
RossD
RossD UltraDork
5/10/12 7:44 a.m.
If you sand stainless, I believe you should do an acid wash to keep it from rusting.
I like the BBQ paint option, though. Or just put a vise on your dash with some flowers in it. No one will try to race you then.
Twin_Cam
Twin_Cam UltraDork
5/10/12 8:23 a.m.
Keith wrote: BBQ paint.
That won't flake off? Then it'll look like every Toyota muffler ever
Curmudgeon
Curmudgeon MegaDork
5/10/12 8:28 a.m.
Wet sand the snot out of it with 400 grit wet/dry paper. Don't worry about rust, it might get a little color to it but that's even more stealth.
And yeah I don't think I have ever seen a Toyota muffler that didn't look like it had leprosy.
motomoron
motomoron Dork
5/10/12 10:16 a.m.
^Yes^
Scuff it w/ 240 wet or dry, degrease w/ acetone or lacquer thinner, shoot w/ VHT high temp black, let it flash off for a while, then drive the car 'til the muffler is heat soaked. It never flakes off and eventually turns that dark grey dirty header color.
Javelin
Javelin UltimaDork
5/10/12 10:23 a.m.
I'd scour it lightly with a copper or brass pad to knock the edge off, then just let it age/dirty up a little.
Keith
Keith MegaDork
5/10/12 10:39 a.m.
I use BBQ paint on some of my exhaust parts. I don't know if I've ever tried it on polished stainless, but if I was worried I'd rub it down with a Scotchbrite pad first.
jere
jere New Reader
5/10/12 11:55 a.m.
In reply to Keith:
I have used BBQ paint on stainless, works good. I actually had to clean it off the other day to resell it....it was stuck on good
CarKid1989
CarKid1989 Dork
5/10/12 7:51 p.m.
wanna buy my OBX cat back?
then you have one to practice on
akamcfly
akamcfly HalfDork
5/10/12 8:47 p.m.
the brown scotchbrite pads do a nice job
novaderrik
novaderrik SuperDork
5/11/12 1:59 a.m.
RossD wrote: If you sand stainless, I believe you should do an acid wash to keep it from rusting. I like the BBQ paint option, though. Or just put a vise on your dash with some flowers in it. No one will try to race you then.
only if you use a piece of sand paper that you had previously used on regular steel.. galvanic corrosion is a neat thing..
dinger
dinger Reader
5/11/12 7:43 a.m.
Get the scotchbrite pads they use for paint prep from a local auto body supply store. Go with the grain of the metal, should give a nice brushed looking effect.
Twin_Cam
Twin_Cam UltraDork
5/11/12 12:18 p.m.
CarKid1989 wrote: wanna buy my OBX cat back? then you have one to practice on
Not if it fits as well as the exhaust. And by well I mean poorly. And also, I have a 2000, which means I have an AIR system...most aftermarket headers don't have the opening for the tube...and removing the system outright throws a SES light, which will fail me on inspections. And I'm poor and can't afford an aftermarket header. But otherwise, yea totally
Sounds like sanding with 240-400 grit sandpaper or a rough Scotchbrite and then black high-temp paint. Thanks guys.
mmosbey
mmosbey Reader
5/12/12 11:21 p.m.
SGdOTV6VSanmMcN3UR7kEjd8yQUp4beM3ODALRNLZQhzqME4hXxZ1Hkf1M09sHbT
