Secret_Chimp
Secret_Chimp New Reader
5/31/16 9:06 a.m.
itsarebuild wrote: I think you need to look at the pedal ratio option first. Bigger MC moves more fluid per stroke but from the art led I've read can reduce force applied at the piston. It sounds like OP is getting pressure, especially when the tears are reduced in fliw, but the pedal travel is worrisome. Altering the relationship between the pedal pivot and the MC may get a faster stroke .
The pushrod is about as high up on the pedal arm as it could go. I'm only about the height of the clevis (1.5in?) below the pivot right now.
itsarebuild
itsarebuild Dork
5/31/16 1:13 p.m.
In reply to Secret_Chimp
Hmmmm. That does make the problem more difficult. It sounds like the bigger bore may be the only answer. And if the pressure drops to much get more boost on the system.
VTX5zNR0HAZhcvJ9PiBAatASwvGKFVhoPFYVGWsH9AEM9661gmJuX88qzuCfDCzD
