glueguy
glueguy HalfDork
11/15/16 5:48 a.m.
I need to use a leakdown tester. The air compressor is a long way away from the car. I have a typical autocrosser 5 gal portable air tank. Can I use the portable tank or will the leakdown use enough air that I want to run a really long hose?
akylekoz
akylekoz Reader
11/15/16 5:53 a.m.
If you use air that fast you have too much leak down. I would run a long hose.
wae
wae Dork
11/15/16 7:40 a.m.
You could probably get away with the portable tank if you do a lot of walking back and forth!
I don't think it's the amount of air that would be the problem, but keeping up the pressure.
Basil Exposition
Basil Exposition SuperDork
11/15/16 9:33 a.m.
Yeah, I doubt that'll work. You need a constant pressure to calculate your leak down percentage. A 5 gallon tank will draw down pretty quickly. No harm trying it first, though. Let us know.
NOHOME PowerDork
11/15/16 10:01 a.m.
When I do this I tape a rubber glove over the tailpipe, the intake and the rocker breather. The one that gives me the finger is the culprit!
imGTXRiyeJLzbMqT6qa8WGbiO3CWKGgR9GAbboVIYEKedHjt6S8GZC5kkpj6t4K7
