Vigo (Forum Supporter)
Vigo (Forum Supporter) MegaDork
9/19/20 9:20 a.m.
Yeah, that wouldn't be that helpful but it did send me on a warp-speed 3 second brainstorm about using a selectable locking center differential and selectable brake on the rear output as a 'gear splitter' cheeky
mini64
mini64 None
8/6/24 2:36 p.m.
Did you ever build your car, figuring out what to do about the gearbox?
8/6/24 7:11 p.m.
aw614 said:
Doesn't the boxster use an 01e transmission in a midengine setup?  I don't see why it can't be used if it does.
VWAG engines with the Audi bolt pattern (any 5, 6, or 8 with a timing belt) will bolt to the Boxster transmission.  The 07K five is a four cylinder pattern, and I don't know about the timing chain V6s and V8s.  VR6 is right out but there are adaptors to mate up where a five used to go.
This is where it is/was popular to put Audi V8s in Boxsters.  It amazes me that they fit smiley
BGMZr5KgEw7kuNsHTAEjwSxCGFDwNbjWOLuXot9QlUfNgkZ3IeKm2qUJACEgQTLt
