Jakeinthepaddock
Jakeinthepaddock
10/9/08 6:06 p.m.
Hi I was wondering about trasmission on 97 jetta I've taken all the bolts out and drive plates 2 times can only get a small gap on the case got a self inflected prodlem on one of the shift forks. Anybody know where the seceret button is? thanks Jake...
fifty
fifty None
10/9/08 8:19 p.m.
What transmission code is it? I had the same problem on a manual trans 1992 VW a couple of nights back (020 family of transmissions). I ended up reading the Bentley manual, the engine needs to be at TDC. There is a mark on the flywheel for TDC. Try it and report back!
Jakeinthepaddock
Jakeinthepaddock New Reader
10/15/08 7:19 a.m.
Hey . fifty Maybe I should be more clear Trans is out on bench.all bolts are out of trans body. need to split case. any ideas? thanks jake..
RXBeetle
RXBeetle New Reader
10/15/08 9:01 a.m.
Should be an 02A (check the code right next to where the starter bolts up This might help http://forums.vwvortex.com/zerothread?id=767717
16vCorey
16vCorey Dork
10/15/08 11:10 a.m.
RXBeetle wrote: Should be an 02A (check the code right next to where the starter bolts up This might help http://forums.vwvortex.com/zerothread?id=767717
Only if it's a VR6. A 4cyl is going to have an 020.
fifty
fifty New Reader
10/15/08 7:29 p.m.
http://www.brokevw.com/
"Broke" on the VW Vortex manual transmission forums has helped me in the past - you might try sending him a PM, or posting a thread there.
Edit - let me know how you make out with it - I have a "2Y" trans that I want to put an LSD in in the next couple of months.
EnfGirmvO6GCC1cLdD8aUOAwPZahrliZJbJbWlEQDbraTmht38YQ5iesfYL2kk1o
