curtis73
curtis73 Dork
10/29/11 10:37 a.m.
So I had read several posts asking if the ValueTrac torsen-type differential was any good and everyone's response was "sounds cheap, don't skimp" but no one had ever posted if they had actually tried it. So I thought... what the hell?
$240 from Ebay, $80 for Koyo bearings and seals. Being installed here in my 96 Impala SS at my shop on Monday. Keep watching.
I'm told that it is very aggressive, and I should expect turning scuffing much like a heavily-sprung clutch-type posi.
Timeormoney
Timeormoney Reader
10/29/11 10:48 a.m.
Sounds like a great experiment
donalson
donalson SuperDork
10/30/11 12:56 a.m.
if my s10 was running an 8.5 i'd be absolutely impatient to hear about your results... still look forward to hearing how it works :)... mega cheap for a torsen LSD thats for sure
novaderrik
novaderrik Dork
10/30/11 2:10 a.m.
donalson wrote: if my s10 was running an 8.5 i'd be absolutely impatient to hear about your results... still look forward to hearing how it works :)... mega cheap for a torsen LSD thats for sure
it would be easy enough to put an 8.5 in your truck- get one from a 70's F body and move the perches in to where they need to be on an S10.. it may be a bit wider, but wheels with more backspacing would be easy to find..
aussiesmg
aussiesmg SuperDork
10/30/11 8:44 a.m.
Source the 8.5 then build a 4 link thereby eliminating the leaf springs and gaining a tunable suspension
Sorta like mine
It was a vast improvement
curtis73
curtis73 Dork
10/30/11 11:13 a.m.
One unadvertised snag on mine. Had to order the oversized carrier bearings. The ValueTrac uses the 1.785" bearing instead of the stock... at least on the one I bought.
donalson
donalson SuperDork
10/30/11 2:13 p.m.
unless I find an 8.5" with LSD already in it i'd go with a ford explorer 8.8 with posi and gain discs for the same price...
aussiesmg
aussiesmg SuperDork
10/30/11 3:35 p.m.
I failed to state mine is an Exploder 8.8
Vigo Dork
10/31/11 1:03 p.m.
Interested to hear how this turns out..
daytonaer
daytonaer Reader
10/31/11 3:45 p.m.
Yay for a cheap torsen setup!
I put my jeep in a ditch this recent snow partly because of a lunch-box locker that stays locked both ways and partly (maybe mostly) because I thought I could hold a drift instead of putting the clutch in and trying to save it.
Paid about $300 for the setup btw and its brutal in parking-lot maneuvers. It was responsible for getting me out of said ditch, so I can't really fault it.
I recall the OBD knockoffs for fwd setups being pretty close to qualfe types other than sub-par hardware, lots of people put in nice bolts and had good units for cheap.
Javelin
Javelin SuperDork
10/31/11 3:49 p.m.
Following this with great interest! Apparently ValueTrac makes a unit for the AMC Model 20 (which is in the Javelin).
8N9JT4RxFQN4eK2kyy8Sm0YLj7NanUDSY35OAdcqFFkaVvYLqcN23fOhD68QkDVT
