paul
paul Reader
3/20/11 1:52 p.m.
I searched the net for a bit, apologies for the noobish question...
I was under the impression that valves which are in need of adjustment may be loose (valve clatter) OR tighter than spec'ed clearances (possibly leading to burnt valves); local web board seems to think when valves wear the gap gets bigger hence needing an adjustment, and clearances can't tighten with use...
Engine in question is a honda k20...
Streetwiseguy
Streetwiseguy Dork
3/20/11 2:30 p.m.
They are wrong. Wear on the rockers, cam, or valve stem will loosen clearances. Wear on seats or valve faces will tighten clearances.
paul
paul Reader
3/20/11 3:09 p.m.
ok, thanks for the input!
ORPMoWmkfCDW7a607LbX8an8VuusVlfEsf9dpbwCipceaCJZIjcn8WQgbci3EM3J
