evildky
evildky SuperDork
8/16/16 9:56 a.m.
Thats a lot of explanation for "we move the crank up and down" Now I wonder how the outdrives work?
WildScotsRacing
WildScotsRacing HalfDork
8/16/16 10:56 a.m.
You guys know that oil refineries have been using various styles of variable compression engines since before WW II, right? It's how they test a batch of fuel to determine the Motor Octane Number; keep upping the compression until the fuel knocks. My grandfather was a petroleum chemist/fuels specialist for Sun Oil from 1940 until he retired in 1983, and I remember him telling me about using their variable compression engine to develop the processes that allowed 115/130 octane avgas to be produced in massive quantity and extreme purity for the war effort.
Anyway, they have been around for a LONG time.
maschinenbau
maschinenbau Reader
8/16/16 10:56 a.m.
The crank doesn't move on this one, the con rod length changes by hinging it.
Flight Service
Flight Service MegaDork
8/16/16 11:18 a.m.
maschinenbau wrote: I bet it doesn't add much weight, probably equivalent to the weight of a few extra con rods. And if you factor in the weight savings from engine downsizing (this 2.0L I4 makes the same power and torque as a 3.5L V6) then the whole package is pretty appealing.
I bet it adds 40~50lbs. You have the con-rods. The positioning mechanism (which isn't going to be flimsy) essentially 1/2 of another crankshaft.
I think this is going to the wrong way and will flop with consumers. Mazdas SkyActive in the 6 with capacitor regen I think will work better.
maschinenbau wrote: The crank doesn't move on this one, the con rod length changes by hinging it.
I think you are getting into a semantic argument. It would depend if you see the hing mechanism as part of the crank, the rod, or another part entirely.
I would say it is another part entirely. It is a device that connects between the crank and the rod. Essentially it is a four-bar linkage.
jstand
jstand HalfDork
8/16/16 11:28 a.m.
Another article
For those that don't like to click links:
And this:
alfadriver
alfadriver MegaDork
8/16/16 11:35 a.m.
In reply to WildScotsRacing:
There's a difference between those engines and ones that go into cars- namely size and weight. I never considered that idea to be transferable.
xflowgolf
xflowgolf Dork
8/16/16 12:06 p.m.
HappyAndy wrote: Wouldn't a Koneggsigg style fully camshaft-less electro-pnuematic valve train be able to accomplish the same thing (with 99% less Rube Goldberg) by selectively Atkinson cycling the intake valves? That looks like a mess
You can effectively reduce the compression by hanging valves as you're suggesting to exhaust back as the cylinder compresses slightly, but the expansion ratio is unchanged.
I agree the "extra" moving parts here make me question longevity/durability.
Knurled
Knurled MegaDork
8/16/16 12:42 p.m.
In reply to jstand:
So they put finger followers on the crankshaft. Neeeeet.
evildky
evildky SuperDork
8/17/16 8:57 a.m.
Oh, that's a much better illustration. The piston now rides on a variable cantilever which rides on the crank. Now with three times the rod bearings!
WildScotsRacing
8/17/16 9:03 a.m.
evildky wrote: Oh, that's a much better illustration. The piston now rides on a variable cantilever which rides on the crank. Now with three times the rod bearings!
All the additional bearings was what I thought of first. This desgn is going to need a hella stout oiling system.
evildky
evildky SuperDork
8/17/16 10:58 a.m.
The bearing on the crankshaft will be under so much load, it's got to shorten it's life.
jstand
jstand HalfDork
8/17/16 11:26 a.m.
They should also update the valve train to keep the top and bottom end balanced.
tuna55
tuna55 MegaDork
8/17/16 11:59 a.m.
This screams at me. It screams:
"I may bring some real fuel economy benefits to the equation but I will bring so much more complexity, parts count, size and weight that I will be worthless!"
alfadriver
alfadriver MegaDork
8/17/16 12:26 p.m.
In reply to tuna55:
It would be interesting to see it run. What we don't do well is make just a little power- so much is compromised to make a lot, that making a little is rough. So that optimum CR when you only need 4-20hp could be 14:1, whereas at WOT, it's closer to 10:1. This could help a lot.
jstand
jstand HalfDork
8/17/16 12:56 p.m.
It could also provide some additional ways to combat low quality/octane fuel. Instead of backing off timing to eliminate knock the ECU could adjust compression or adjust both.
In a flex fuel configuration you could take advantage of some of the benefits of e85 that are lost on a fixed CR engine. That could help offset the lost fuel economy normally seen when running e85.
alfadriver
alfadriver MegaDork
8/17/16 1:08 p.m.
In reply to jstand:
The dream flex fuel engine.
Zs7x2mODJDGLJVzoGXxQj8A1UTJEVk67IQSNyZhQ7uXtyxNS4QLhGVZAm1zjcdzP
