![feature_image](https://s3.us-east-2.amazonaws.com/prod.mm.com/cache/1a/46/1a460277e54abaf3e952a8da95879bd2.jpg)
One way to find more speed on track? Check your car’s alignment–which you can do from the comfort of your own garage.
This is how we checked the alignment on our Porsche Cayman by using SmartStrings and SmartCamber from Smart Racing Products.
You need toe in at the rear of your Cayman. At zero toe, the rear will become quite twitchy under hard braking. As the rear goes into rebound, the toe change is negative (out). Also, is the floor of your facility level? The difference between LF and RF camber would seem to indicate a slant to the floor.
