DukeOfUndersteer
DukeOfUndersteer PowerDork
5/10/12 6:11 p.m.
So... updating the Volvo when I get back to Georgia.
Getting these wheels:
18x8, et 20 redrilled to 5x108.
Coilovers:
XYZ, don't think they are bump/rebound adjustable, just enough to bump around town.
New turbo:
or rebuild the current one
I want to build a Big Brake kit from a set of Porsche 993TT front calipers and S60R front rotors, but it would cost me the same as buying a kit from IPD. Would need Carriers and pads and shims, ect...
Gonna be one cool Wagon when done!!
Anti-stance
Anti-stance HalfDork
5/10/12 6:49 p.m.
:popcorn:
DukeOfUndersteer
5/10/12 6:52 p.m.
haha! Been talkin with Gary Whitt. I should be at Rd. Atl in June. Wish you were gonna be there!
DaewooOfDeath
DaewooOfDeath Dork
5/10/12 7:20 p.m.
<- See my avatar? I'm making that face right now. I demand pictures of this Volvo!
JtspellS
JtspellS Reader
5/10/12 7:22 p.m.
Pics or it did not happen!!!!!!!!
westsidetalon
westsidetalon Reader
5/10/12 7:27 p.m.
In reply to JtspellS: how much are those coilovers? about to build a diy set.
DukeOfUndersteer
5/10/12 7:29 p.m.
DaewooOfDeath wrote: <- See my avatar? I'm making that face right now. I demand pictures of this Volvo!
Sitting stock right now. In do time child...
JtspellS wrote: Pics or it did not happen!!!!!!!!
haha, again, in due time child...
DukeOfUndersteer
5/10/12 7:31 p.m.
westsidetalon wrote: In reply to JtspellS: how much are those coilovers? about to build a diy set.
on flebay for $900 buy it now. Would like to get a set of KWs, but these will do. Will try and get Jessica into some autox'ing
Anti-stance
5/10/12 8:36 p.m.
DukeOfUndersteer wrote: haha! Been talkin with Gary Whitt. I should be at Rd. Atl in June. Wish you were gonna be there!
I will probably be there working.
DukeOfUndersteer
5/10/12 9:24 p.m.
Then I'll probably see you in June!
Fit_Is_Slo
Fit_Is_Slo HalfDork
5/10/12 9:38 p.m.
Really?!
DukeOfUndersteer
5/10/12 10:16 p.m.
Really?!
Yep! you going?
Trans_Maro
Trans_Maro SuperDork
5/10/12 10:41 p.m.
Call up Lucky at ARDIdeas and get one of his tuned ECUs.
I love the one he did for my 850.
Shawn
DukeOfUndersteer
5/11/12 6:40 a.m.
Trans_Maro wrote: Call up Lucky at ARDIdeas and get one of his tuned ECUs. I love the one he did for my 850. Shawn
Was planning on getting one. How much are they?
Ian F
Ian F UberDork
5/11/12 7:29 a.m.
Question for you. Are the camber plates with the kit the ones in the picture above? Ones that appear to be a solid bearing mount with no rubber isolator? If so, I'd have reservations about installing these if you plan to use the car primarily on the street. I just pulled a set of these off a MINI for the primary reason they made the ride absolutely intolerable on crappy NJ roads. I replaced them with a set of fixed camber plates with rubber isolators and the street ride was much improved.
Another thing... ET20 on a FWD car? That doesn't sound right. The 17x8 wheels I just pulled off the g/f's 850 had a lot more offset (35+ IIRC) and still hit the fender lips.
jonnyd330
jonnyd330 Reader
5/11/12 8:54 a.m.
Are 850's easy to work on? How are parts cost?
dculberson
dculberson Dork
5/11/12 8:59 a.m.
850's are very easy to work on. The parts are reasonable; not cheap but not as costly as many other European makes. Aftermarket parts can be pretty cheap.
Ian F
Ian F UberDork
5/11/12 9:01 a.m.
...as long as you don't need a new automatic transmission...
dculberson
dculberson Dork
5/11/12 9:18 a.m.
Oh, crap! Did the trans go out on your girlfriend's car?
Trans_Maro
5/11/12 9:33 a.m.
I went with the orange tune but I think I'll step up to the green after a few more mods.
You can get them direct from ARD here: http://www.ardideas.com/1994-1997tuning.html
They are cheaper coming from Snabb, it's the genuine article from ARD, just at a better price: http://www.snabb.us/
Before you do any of that, get the car to a solid stage 0 state: http://www.matthewsvolvosite.com/what-is-stage-0.html
I still need to replace the pcv system as it is pretty badly clogged on my car, just need to find the time to do it. I'll be installing one of Snabbs intake manifold insulators at the same time.
Also, if you're going to replace the rubber elbow in the intercooler plumbing (a good idea since they're probably a bit dry by now), the silicone kit is about $200.00 but a cheap eBay front-mount intercooler with the piping and silicone elbow is about $150 from CXracing.
Shawn
Ian F
Ian F UberDork
5/11/12 9:42 a.m.
dculberson wrote: Oh, crap! Did the trans go out on your girlfriend's car?
Yep. Due to a lack of time and the fact none of the diagnostic programs she bought would "talk" to the transmission controller, she finally broke down and took it to a local Volvo specialist. They waived their more fancy computer wand over it and said none of the codes they were getting indicated it would be something that could be fixed easily (replacing the solenoids, for example) and recommended a new trans.
NOT cheap, unfortunately. Hopefully it means the car will be good for at least another 100K miles... I've replaced damn near everything else...
She mused about doing an ECU tune, but if that means putting more stress on the transmission there isn't a fat chance in hell now.
DukeOfUndersteer
5/11/12 5:57 p.m.
Ian F wrote: Question for you. Are the camber plates with the kit the ones in the picture above? Ones that appear to be a solid bearing mount with no rubber isolator? If so, I'd have reservations about installing these if you plan to use the car primarily on the street. I just pulled a set of these off a MINI for the primary reason they made the ride absolutely intolerable on crappy NJ roads. I replaced them with a set of fixed camber plates with rubber isolators and the street ride was much improved. Another thing... ET20 on a FWD car? That doesn't sound right. The 17x8 wheels I just pulled off the g/f's 850 had a lot more offset (35+ IIRC) and still hit the fender lips.
I am assuming that is just a generic picture used. I thought they had a camber adjustment bolt. If they do come with a set of plates, I'll figure out something, to see if they will work or not.
As for the wheels, it is going to take a lot of fender rolling to get them to fit. If not, guess they will be getting box flares...
TGeiPCWplHzGH1KKGd5vu7fULWvxsiLTtIOxfV9dDgKc4Es6fRaHxfZjh7JNvFDY
