SVreX
SVreX SuperDork
3/6/11 11:02 p.m.
I'm looking for hub bearing housings for using standard VW hubs and bearings from a water cooled VW in a custom fabrication.
Something like this, but for the water cooled front hubs:
Hub housings
I'm trying to custom fabricate trailing arms, but I want to use all VW components (hubs, CV's, brake calipers, wheels, etc.)
This will be a custom rear IRS using FWD components. Don't really want to use the complete front spindle assembly.
Anyone know any sources?
jimbbski
jimbbski Reader
3/6/11 11:10 p.m.
M0ost likey a one off item. Could be made on a lathe. Not hard to make. You need to come up with a design and specs. Then any machine shop could make it.
fasted58
fasted58 New Reader
3/6/11 11:52 p.m.
I would assume you're not using a flange mount like the one in the link so this would just be a sleeve welded into a fabricated hub carrier... yea, easy machine shop job. Plan for enough sleeve wall thickness so it's not too thin at the internal lock ring grooves.
I had a project like this planned about 15 years ago, still might have some new 64mm bearings and stub axles.
SVreX
SVreX SuperDork
3/7/11 6:37 a.m.
I know I could make them. I was looking for a pre-fab piece.
thummmper
thummmper New Reader
3/7/11 10:07 a.m.
sand car suppliers--mckenzies----are you running power through these?
SVreX
SVreX SuperDork
3/7/11 3:15 p.m.
Yes.
SVreX
SVreX SuperDork
3/7/11 6:29 p.m.
Local machine shop wants over $200 to make these, and I don't have a lathe right now, so I'd much rather find a piece I can adapt (since it is for a Challenge car).
Anybody have a lathe??
Supercoupe
Supercoupe Reader
3/7/11 6:42 p.m.
ewww..whatcha buildin'
thummmper
3/7/11 9:29 p.m.
these are vanagon rears--I am discarding them to weld on 1988 beamer 735i rear drumdiscs--have a look and the frankenbrakes these are jy ready--seems that is the cheapest source anymore
jimbbski
jimbbski Reader
3/7/11 9:58 p.m.
If your plan on using VW size bearings and CVs could you start out with stock bearing carrier/steering knuckle and just cut off the excess metal then machine whats left to a finished OD? That i could do as i have a lathe. Machineing the ID to the close fit for a bearing and then adding the snap ring groves is tricky if you don't have the correct tooling, and I don't.
SVreX
SVreX SuperDork
3/8/11 7:07 a.m.
jimbbski:
I'm leaning that way. I've got plenty of spare knuckles.
Are you offering to help?
SVreX
SVreX SuperDork
3/9/11 2:30 p.m.
Supercoupe wrote: ewww..whatcha buildin'
I'll tell you that the ultimate target is 5.7 lbs/ hp.
fasted58
fasted58 New Reader
3/9/11 4:10 p.m.
Lemme guess, bike engine? ala D Sports Racer
SVreX
SVreX SuperDork
3/9/11 6:13 p.m.
VW engine.
jimbbski
jimbbski Reader
3/9/11 6:27 p.m.
SVreX wrote: jimbbski: I'm leaning that way. I've got plenty of spare knuckles. Are you offering to help?
We can talk about it.
O0bRU9yqftnZuqOKCb7OxUpI67PgRQPQgfPdxkjLoXP4Jr3cqK9uRNEau534VLdN
