3 4 5
robert777
robert777 New Reader
3/20/24 3:43 p.m.
Concerning this: Bad news, the left-rear axle has positive camber.
I am pretty sure that axle tube can be removed, flipped and re-installed to gain that same amount of negative camber.
You will probably need to re-drill the bolt holes where it bolts the the center housing and also remount the brake and shock/spring mounts. Those are usually bolt on units that are then tack welded in place.
3 4 5
oSqpNMUKo8Tm0L85234idBBAuxfinmXhAUCmf7It5d9YgaiqoTmOTtKj4Pj6d0Vk
