96DXCivic
96DXCivic HalfDork
3/3/10 4:59 p.m.
Does anyone know the differences in weight between these three series of engines?
DILYSI Dave
DILYSI Dave SuperDork
3/3/10 5:07 p.m.
96DXCivic wrote: Does anyone know the differences in weight between these three series of engines?
B > K > D
B = D+ 125
K = D + 80
All IIRC.
jwdmotorsports
jwdmotorsports Dork
3/3/10 5:59 p.m.
I know it wasn't part of the original question where does the H series fall? Heavier than all three?
Also, is there much difference in weight between the dohc and sohc d series.
carguy123
carguy123 SuperDork
3/3/10 6:42 p.m.
The K series is absolutely HUGE, it can't weigh less than the B series.
DILYSI Dave
3/3/10 6:49 p.m.
carguy123 wrote: The K series is absolutely HUGE, it can't weigh less than the B series.
There's a lot of air. The K is lighter.
93celicaGT2
93celicaGT2 SuperDork
3/3/10 6:59 p.m.
jwdmotorsports wrote: I know it wasn't part of the original question where does the H series fall? Heavier than all three? Also, is there much difference in weight between the dohc and sohc d series.
H/F-series is the heaviest. And no, no difference worth fighting over between the dohc and sohc d-slammers.
3Door4G
3Door4G New Reader
3/3/10 8:53 p.m.
I thought the K was heavier as well. I guess that's what I learned today.
integraguy
integraguy HalfDork
3/4/10 11:14 a.m.
I have limited experience with the weights of Honda's engines....usually, the biggest issue when a swap is contemplated is the external dimensions. I believe the "K" family (K20 and K24) are the TALLEST , but the "H" family and "F" family....because they were produced in large displacements (which made them quite tall), are right up there with the "K".
93celicaGT2
3/4/10 11:29 a.m.
integraguy wrote: I have limited experience with the weights of Honda's engines....usually, the biggest issue when a swap is contemplated is the external dimensions. I believe the "K" family (K20 and K24) are the TALLEST , but the "H" family and "F" family....because they were produced in large displacements (which made them quite tall), are right up there with the "K".
K-series are tallest, but the way they sit actually allow for more clearance than the H-series. Try sitting an H23 in an EG hatch sometime. You get to space that hood about 2" for that jdm tyte look, y0.
y1IszwY3yFyf9SZ317tZmgcyFh4LKnRMTySXW7djk6J8favVRSjFuuYugIhoYCz9
