Per Schroeder
Per Schroeder PowerDork
12/5/08 6:52 a.m.
The square, steel-tube portions of the LeGrand are joined together by brazing in many spots. This is an accepted method of joining pieces of chromoly tubing and minimizes localized heating. It keeps the chromoly steel from becoming brittle around the welded areas.
Pete, dad of GRM Tech Editor Per, …
turboswede
turboswede UltimaDork
12/5/08 3:37 p.m.
Bummer, might be worth checking the others as well, JIC.
So, what is the yellow car in the background of the second photo?
Gonzo_Bmod
Gonzo_Bmod Reader
12/5/08 4:32 p.m.
Tub looks good. Those welds around the lower trailing arm mounting points are notorious apparently. Hope to see pics of how you end up doing the job. What IS that cool yellow thing in the garage!
thatsnowinnebago
thatsnowinnebago Dork
12/7/08 2:25 a.m.
Really though, what's that fancy yellow car?
Per Schroeder
12/7/08 3:56 p.m.
That's my dad's GTM, it's a mid-engined fiberglass car made in the UK using a Honda B16. It makes an Elise look fat.
Hasbro
Hasbro SuperDork
12/8/08 1:08 a.m.
We require pics of the GTM.
Per Schroeder
12/8/08 5:40 a.m.
http://www.manikllc.com/brochures/GTM_Libra_kit.pdf
matt_fulghum
matt_fulghum New Reader
12/9/08 9:30 p.m.
TIG weld it. Standard high quality E70S-2 filler rod will flow right into the weld happily, and it'll most likely be quite a bit stronger than a rebrazed joint. You don't need to heat-treat it or anything either, since the HAZ on a tig weld is really tight.
TuNneLvision
TuNneLvision
1/10/09 1:19 a.m.
That looks like a repair braze . It is also a poor attempt at a repair . The brazing is "cold" and didn't flow out properly . The crack may just be the braze itself and not the underlying metal . You will have to gring off the surrounding braze and check the steel structure . If that looks OK, the rebraze with some quality brazing rod . Yes, it costs more but its cheap considering the consequences for that joint . If the steel is indeed cracked, then you will need to fabricate a doubler plate and braze that around the joint to provide the load bearing strength to an underdesigned joint .
You cannot TIG with a steel rod for this joint as the brazing material will contaminate the weld and you will make a true mess of the joint . Also, heat treating has nothing to do with the HAZ . Heat treating is to change the mechanical properties of the base metal by a controlled thermal processes . It will treat the whole structure and not just the joint . You also cannot heat treat any brazed structure as the lowest heat treating process will melt the braze and then you have no structure !
3U7RFubTJGaAmeJNxquf6wjpWAUkyHGSNrvZ3oJjD82XqXSFIDnLeHg71R5fbFPv
