Or should I just have a friend with a lathe make them for me? I picked up a set of camber plates and now I need those aluminum bushing spacer things that make up the gap between the strut insert's top mounting threaded pin and the pillow ball that pivots in the center of the camber plate. What exactly do they look like anyway? Are they 2 piece? Is their a large flat shoulder on the bottom and top? I am using 2.5" coil over springs and plan to run one of those aluminum spring top hats that come in the Ebay coil over kits. Can't figure out how the hat, the insert, and the camber plate all mesh together. In the past, I have always used a modified stock strut top, but that top mount limits how much adjustability you can get. That smaller aluminum hat would be much better. All I can find is some pictures of what comes in a Ground Control kit, and I can see why they get so much for their stuff.
