frenchyd
frenchyd MegaDork
8/29/23 9:36 p.m.
The last Jaguar V12's didn't have a distributor.  They ECM  basically triggered 6 coils with 2 leads on each coil.  When one cylinder fires  the other cylinder dry fires on the exhaust stroke.
   Mine is a basic Megasquirt  2357-C
 if all I want to do is control the spark can I use this?  It's a major pain to adjust timing on a V12. The distributor only allows 3 degrees of timing change.  Even that requires taking it 1/2 way apart then adjusting it blind and reassembling  then crawling underneath to see the timing marks on the bottom of the engine.
Racingsnake
Racingsnake Reader
8/29/23 9:52 p.m.
I thought one of the virtues of the V12 that you've extolled is that the distributor was right on top and easy to get at lol
8/29/23 10:35 p.m.
What can't you do with a Megasquirt? cheeky
You can definitely run the V12's ignition in wasted spark mode similar to the factory system. You'll have to set up multiple injectors to be fired by a single injector driver, discussed here:
https://forum.etypeuk.com/viewtopic.php?f=6&t=15380&sid=f0367f3ff9df047a6fb9ec7ca876555d&start=20
frenchyd
frenchyd MegaDork
8/29/23 10:58 p.m.
I won't be using the fuel injection.  To run in group 6 I have to use carbs.  So all I need to do is control the ignition.
frenchyd
frenchyd MegaDork
8/29/23 11:04 p.m.
Oh it is easy to get at.  Plus I do have my own distributor machine so it's straight forward  for me to get it to do what I need it to do.
    It's just so much more work  over a few key strokes.
  I admit I've learned a lot watching  video's and attending a few dyno sessions.
MadScientistMatt
MadScientistMatt UltimaDork
8/30/23 12:30 p.m.
You can set up that Megasquit for six spark outputs, but it's either a very involved solder job or swapping to an MS3 processor and MS3X card.
Paul_VR6 (Forum Supporter)
Paul_VR6 (Forum Supporter) UltraDork
8/30/23 1:04 p.m.
I have definitely done a 6 coil version for a BMW and it wasn't fun. I can be persuaded with money to do another.
frenchyd
frenchyd MegaDork
8/30/23 1:24 p.m.
That's kinda what I thought.  What do you think it would cost me to swap my  current new, unused MS2  for the MS3X card and MS3 processor?
8/30/23 3:14 p.m.
I give a $100 credit for MS2 to MS3 upgrade (I keep MS2 processor). $150 for labor and the parts are around $500 for the MS3, 3x and 8' harness.
frenchyd
frenchyd MegaDork
8/30/23 3:29 p.m.
That sounds very fair.
8/30/23 3:34 p.m.
It definitely could be worse, I'd charge 500 just to put 6 BIP coil drivers on a MS2/3.57 it sucks a bit. The only caveat is you need to use coils with amps with the 3x drivers.
frenchyd
frenchyd MegaDork
8/31/23 4:39 p.m.
Would I be ahead if I bought an upscale MS?   Something like a pro?
6IaRB44hTqejaXljRxNEYiL19O8fN2TLsZyhdKMVfm9ktDEr9n7KvEg38kgcBzCc
